A Case Study in Model-based Adaptation of Web Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Developing systems through the composition of reusable software services is not straightforward in most situations since different kinds of mismatch may occur among their public interfaces. Service adaptation plays a key role in the development of such systems by solving, as automatically as possible, mismatch cases at the different interoperability levels among interfaces by synthesizing a mediating adaptor between services. In this paper, we show the application of model-based adaptation techniques for the construction of service-based systems on a case study. We describe each step of the adaptation process, starting with the automatic extraction of behavioural models from existing interface descriptions, until the final adaptor implementation is generated for the target platform.
CamaraISOLA2010.pdf (492.5 Ko) Télécharger le fichier
inria-00538968 , version 1 (23-11-2010)
  • HAL Id : inria-00538968 , version 1
Javier Cámara, Jose Antonio Martin, Gwen Salaün, Carlos Canal, Ernesto Pimentel. A Case Study in Model-based Adaptation of Web Services. 4th International Symposium on Leveraging Applications of Formal Methods, Verification and Validation (ISoLA 2010), Oct 2010, Heraclion, Crete, Greece. pp.112--126. ⟨inria-00538968⟩
283 Consultations
156 Téléchargements
