Maximum Contact Map Overlap Revisited, Journal of Computational Biology, vol.18, issue.1, pp.1-15, 2011. ,
DOI : 10.1089/cmb.2009.0196
URL : https://hal.archives-ouvertes.fr/inria-00536624
An Efficient Lagrangian Relaxation for the Contact Map Overlap Problem, WABI '08: Proc. of the 8th Int. Workshop on Algorithms in Bioinformatics, pp.162-173, 2008. ,
DOI : 10.1007/978-3-540-87361-7_14
URL : https://hal.archives-ouvertes.fr/inria-00327135
1001 Optimal PDB Structure Alignments: Integer Programming Methods for Finding the Maximum Contact Map Overlap, Journal of Computational Biology, vol.11, issue.1, pp.27-52, 2004. ,
DOI : 10.1089/106652704773416876
The structural alignment between two proteins: Is there a unique answer?, Protein Science, vol.221, issue.7, pp.1325-1338, 1996. ,
DOI : 10.1002/pro.5560050711
Flexible algorithm for direct multiple alignment of protein structures and seequences, CABIOS, vol.10, pp.587-596, 1994. ,
Algorithmic aspects of protein structure similarity, 40th Annual Symposium on Foundations of Computer Science (Cat. No.99CB37039), pp.512-521, 1999. ,
DOI : 10.1109/SFFCS.1999.814624
Joining Softassign and Dynamic Programming for the Contact Map Overlap Problem, LNCS, vol.4414, pp.410-423, 2007. ,
DOI : 10.1007/978-3-540-71233-6_32
Fast overlapping of protein contact maps by alignment of eigenvectors, Bioinformatics, vol.26, issue.18, pp.2250-2258, 2010. ,
DOI : 10.1093/bioinformatics/btq402
Protein Structure Comparison: From Contact Map Overlap Maximisation to Distance-based Alignment Search Tool, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00509142
Shrec-10 track: Protein models, 3DOR: Eurographics Workshop on 3D Object Retrieval, pp.117-124, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00536680
A simple and fast heuristic for protein structure comparison, BMC Bioinformatics, vol.9, issue.1, p.161, 2008. ,
DOI : 10.1186/1471-2105-9-161
Optimal Protein Structure Alignment Using Maximum Cliques, Operations Research, vol.53, issue.3, pp.389-402, 2005. ,
DOI : 10.1287/opre.1040.0189
A Reduction-Based Exact Algorithm for the Contact Map Overlap Problem, Journal of Computational Biology, vol.14, issue.5, pp.637-654, 2007. ,
DOI : 10.1089/cmb.2007.R007
