Memory-Based Active Learning for French Broadcast News
Stochastic dependency parsers can achieve very good results when they are trained on large corpora that have been manually annotated. Active learning is a procedure that aims at reducing this annotation cost by selecting as few sentences as possible that will produce the best possible parser. We propose a new selective sampling function for Active Learning that exploits two memory-based distances to find a good compromise between parser uncertainty and sentence representativeness. The reduced dependency between both parsing and selection models opens interesting perspectives for future models combination. The approach is validated on a French broadcast news corpus creation task dedicated to dependency parsing. It outperforms the baseline uncertainty entropy-based selective sampling on this task. We plan to extend this work with self- and co-training methods in order to enlarge this corpus and produce the first French broadcast news Tree Bank.
