Diagnosability for Patterns in Distributed Discrete Event Systems
A pattern is a Finite State Machine that can describe rich faulty scenarios, such as the occurrence of single faults, multiple faults, multiple occurrences of a fault, or the repair of a system. In distributed systems, the events in the pattern, as well as in the system trajectories, are emitted from different components. Our approach is based on distributed simulation and communication to check the recognition of the pattern from the conclusion of local recognition of local patterns. The components communicate observable events and shared communication events, as well as their local recognition results during the checking process without sharing their local models in any way.
