The GIVE-2 Nancy Generation Systems NA and NM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
This paper presents the two instruction generation systems submitted by the team TALARIS at INRIA-Nancy to the GIVE- 2 challenge 2010. The first system (NM) aims to provide high-level instructions by giving freedom to the user and relies on an extension of the Dale and Reiter's in- cremental algorithm to generate the refer- ring expressions. The second system (NA) uses a more constrained directive naviga- tional strategy and relies on Reference Do- main Theory (Denis, 2010) to generate a wide range of referring expressions in- cluding pronouns, ellipsis and alternative phrases. The results show that despite NA is more successful than NM, NM is consid- ered a bit more enjoyable by the subjective assessment.
GIVE-2-Nancy-1.pdf (372.76 Ko) Télécharger le fichier
inria-00541578 , version 1 (30-11-2010)
  • HAL Id : inria-00541578 , version 1
Alexandre Denis, Marilisa Amoia, Luciana Benotti, Laura Perez-Beltrachini, Claire Gardent, et al.. The GIVE-2 Nancy Generation Systems NA and NM. [Research Report] 2010. ⟨inria-00541578⟩
130 Consultations
156 Téléchargements
