A poroelastic model valid in large strains with applications to perfusion in cardiac modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Mechanics Année : 2010
This paper is motivated by the modeling of blood flows through the beating myocardium, namely cardiac perfusion. As in other works, perfusion is modeled here as a flow through a poroelastic medium. The main contribution of this study is the derivation of a general poroelastic model valid for a nearly incompressible medium which experiences finite deformations. A numerical procedure is proposed to iteratively solve the porous flow and the nonlinear poroviscoelastic problems. Three-dimensional numerical experiments are presented to illustrate the model. The first test cases consist of typical poroelastic configurations: swelling and complete drainage. Finally, a simulation of cardiac perfusion is presented in an idealized left ventricle embedded with active fibers. Results show the complex temporal and spatial interactions of the muscle and blood, reproducing several key phenomena observed in cardiac perfusion.
perfusion_final.pdf (551.68 Ko) Télécharger le fichier
inria-00542672 , version 1 (22-06-2013)
Dominique Chapelle, Jacques Sainte-Marie, Jean-Frédéric Gerbeau, Irene Vignon-Clementel. A poroelastic model valid in large strains with applications to perfusion in cardiac modeling. Computational Mechanics, 2010, 46 (1), pp.91-101. ⟨10.1007/s00466-009-0452-x⟩. ⟨inria-00542672⟩
618 Consultations
779 Téléchargements
