Somniloquy: augmenting network interfaces to reduce pc energy usage, NSDI'09: Proceedings of the 6th USENIX RR, p.7473 ,
Energy ecient allocation of virtual machines in cloud data centers. Cluster Computing and the Grid, IEEE International Symposium on, vol.3, issue.33, p.577578, 2010. ,
Power and energy management for server systems, Computer, vol.37, issue.11, 2003. ,
DOI : 10.1109/MC.2004.217
What lies within: Improving the eciency of internal power supplies, 2008. ,
Grid'5000: a large scale and highly reconfigurable grid experimental testbed, The 6th IEEE/ACM International Workshop on Grid Computing, 2005., p.99106, 2005. ,
DOI : 10.1109/GRID.2005.1542730
URL : https://hal.archives-ouvertes.fr/hal-00684943
Dierentiated multimedia web services using quality aware transcoding, 2000. ,
DOI : 10.1109/infcom.2000.832271
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.33.287
Energy-aware server provisioning and load dispatching for connection-intensive internet services, NSDI'08: Proceedings of the 5th USENIX Symposium on Networked Systems Design and Implementation, p.337350, 2008. ,
The GREEN-NET framework: Energy efficiency in large scale distributed systems, 2009 IEEE International Symposium on Parallel & Distributed Processing, 2002. ,
DOI : 10.1109/IPDPS.2009.5160975
URL : https://hal.archives-ouvertes.fr/ensl-00474732
LINPACK Benchmark, p.803820, 2003. ,
DOI : 10.1007/978-0-387-09766-4_155
Power management for main memory with access latency control, 2002. ,
Energy conservation policies for web servers, Proceedings of the 4th USENIX Symposium on Internet Technologies and Systems, pp.3-5, 2003. ,
Memory controller policies for DRAM power management, Proceedings of the 2001 international symposium on Low power electronics and design , ISLPED '01, pp.129-134, 2001. ,
DOI : 10.1145/383082.383118
The Synergy Between Power-Aware Memory Systems and Processor Voltage Scaling, PACS, p.164179, 2003. ,
DOI : 10.1109/92.920816
Snooze: A Scalable, Fault-Tolerant and Distributed Consolidation Manager for Large-Scale Clusters, 2010 IEEE/ACM Int'l Conference on Green Computing and Communications & Int'l Conference on Cyber, Physical and Social Computing, 2010. ,
DOI : 10.1109/GreenCom-CPSCom.2010.62
URL : https://hal.archives-ouvertes.fr/inria-00529702
Green supercomputing comes of age, IT Professional, vol.10, issue.31, p.1723, 2008. ,
The green500 list: Year one, 5th IEEE Workshop on High-Performance, Power-Aware Computing (in conjunction with the 23rd International Parallel and Distributed Processing Symposium), 2001. ,
Power and energy proling of scientic applications on distributed systems, IPDPS '05: Proceedings of the 19th IEEE International Parallel and Distributed Processing Symposium (IPDPS'05) -Papers, 2005. ,
Using multiple energy gears in mpi programs on a power-scalable cluster, PPoPP '05: Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming, p.164173, 2005. ,
Analyzing the energytime trade-o in high-performance computing applications, IEEE Trans. Parallel Distrib. Syst, vol.18, issue.6 24, p.835848, 2007. ,
Exploring the energy-time tradeo in mpi programs on a power-scalable cluster, IPDPS '05: Proceedings of the 19th IEEE International Parallel and Distributed Processing Symposium (IPDPS'05) -Papers, pp.4-5, 2005. ,
Powerpack: Energy proling and analysis of high-performance systems and applications. Parallel and Distributed Systems, IEEE Transactions on, issue.99 1 22, 2010. ,
Improvement of powerperformance eciency for high-end computing, IPDPS '05: Proceedings of the 19th IEEE International Parallel and Distributed Processing Symposium (IPDPS'05, p.233, 2005. ,
Increasing data center eciency with server power measurements, 2002. ,
Comparing algorithms for dynamic speedsetting of a low-power cpu, 1995. ,
Reducing the Energy Consumption of Ethernet with Adaptive Link Rate (ALR), IEEE Transactions on Computers, vol.57, issue.4, pp.448461-448463, 2008. ,
DOI : 10.1109/TC.2007.70836
Dynamic Ethernet Link Shutdown for Energy Conservation on Ethernet Links, 2007 IEEE International Conference on Communications, p.61566161, 2002. ,
DOI : 10.1109/ICC.2007.1019
A feasibility study for power management in LAN switches, Proceedings of the 12th IEEE International Conference on Network Protocols, 2004. ICNP 2004., p.361371, 2004. ,
DOI : 10.1109/ICNP.2004.1348125
Energy conservation in heterogeneous server clusters, Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '05 ,
DOI : 10.1145/1065944.1065969
Entropy, Proceedings of the 2009 ACM SIGPLAN/SIGOPS international conference on Virtual execution environments, VEE '09, p.4150, 2009. ,
DOI : 10.1145/1508293.1508300
URL : https://hal.archives-ouvertes.fr/inria-00320204
Eective dynamic voltage scaling through cpu-boundedness detection, Workshop on Power Aware Computing Systems, p.135149, 2004. ,
Voltage scheduling problem for dynamically variable voltage processors, Proceedings of the 1998 international symposium on Low power electronics and design , ISLPED '98, 1998. ,
DOI : 10.1145/280756.280894
Slurm: Simple linux utility for resource management, Lecture Notes in Computer Science: Proceedings of Job Scheduling Strategies for Parallel Processing (JSSPP) 2003, p.4460, 2002. ,
Worst-case performance bounds for simple onedimensional packing algorithms, SIAM J. Comput, vol.33, issue.4 33, p.299325, 1974. ,
Applying green computing to clusters and the data center, Linux Symposium, vol.3, issue.32, 2008. ,
Server-Level Power Control, Fourth International Conference on Autonomic Computing (ICAC'07), 2007. ,
DOI : 10.1109/ICAC.2007.35
An energy-saving application live placement approach for cloud computing environments, CLOUD '09: Proceedings of the 2009 IEEE International Conference on Cloud Computing, p.1724, 2009. ,
Performance directed energy management for main memory and disks, Trans. Storage, vol.1, issue.3, p.346380, 2002. ,
Migrating server storage to SSDs, Proceedings of the fourth ACM european conference on Computer systems, EuroSys '09, p.145158, 2009. ,
DOI : 10.1145/1519065.1519081
Virtualpower: coordinated power management in virtualized enterprise systems, SOSP '07: Proceedings of twenty-rst ACM SIGOPS symposium on Operating systems principles, p.265278, 2007. ,
Chasing Gaps between Bursts: Towards Energy Efficient Large Scale Experimental Grids, 2008 Ninth International Conference on Parallel and Distributed Computing, Applications and Technologies, p.381389, 2008. ,
DOI : 10.1109/PDCAT.2008.80
URL : https://hal.archives-ouvertes.fr/ensl-00469221
Load balancing and unbalancing for power and performance in cluster-based systems, Workshop on Compilers and Operating Systems for Low Power, 2001. ,
Energy conservation for server systems, Director-Bianchini, 2005. ,
Dynamic voltage scaling on a low-power microprocessor, Proceedings of the 7th annual international conference on Mobile computing and networking , MobiCom '01, p.251259, 2001. ,
DOI : 10.1145/381677.381701
TSB: A DVS algorithm with quick response for general purpose operating systems, Journal of Systems Architecture, vol.54, issue.1-2, p.114, 2008. ,
DOI : 10.1016/j.sysarc.2007.03.006
Making a case for a Green500 list, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639600
Real time power estimation and thread scheduling via performance counters, ACM SIGARCH Computer Architecture News, vol.37, issue.2, p.4655, 2009. ,
DOI : 10.1145/1577129.1577137
Energy-aware data prefetching for multi-speed disks in video servers, Proceedings of the 15th international conference on Multimedia , MULTIMEDIA '07, p.755758, 2007. ,
DOI : 10.1145/1291233.1291403
Energy-aware task and interrupt management in linux, 2003. ,
Dynamic voltage scaling in mobile devices, 2003. ,
pMapper: Power and Migration Cost Aware Application Placement in Virtualized Systems, Middleware '08: Proceedings of the 9th ACM/IFIP/USENIX International Conference on Middleware, p.243264, 2008. ,
DOI : 10.1109/MC.2003.1250880
Cluster-level feedback power control for performance optimization, 2008 IEEE 14th International Symposium on High Performance Computer Architecture, p.110, 2002. ,
DOI : 10.1109/HPCA.2008.4658631
High-Density Computing: A 240-Processor Beowulf in One Cubic Meter, ACM/IEEE SC 2002 Conference (SC'02), p.111, 2002. ,
DOI : 10.1109/SC.2002.10010
Scheduling for Reduced CPU Energy, 1994. ,
DOI : 10.1007/978-0-585-29603-6_17
