New interface
Journal articles
Analysis of a stabilized finite element method for fluid flows through a porous interface
Alfonso Caiazzo 1 Miguel Angel Fernández 1 Vincent Martin 2
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : This work is devoted to the numerical simulation of an incompressible fluid through a porous interface, modeled as a macroscopic resistive interface term in the Stokes equations. We improve the results reported in [M2AN, 42(6):961-990, 2008], by showing that the standard Pressure Stabilized Petrov-Galerkin (PSPG) finite element method is stable, and optimally convergent, without the need for controlling the pressure jump across the interface.
Document type :
Journal articles
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/inria-00543014
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Sunday, December 5, 2010 - 11:11:39 AM
Last modification on : Friday, January 21, 2022 - 3:21:15 AM
Long-term archiving on: : Monday, November 5, 2012 - 11:21:03 AM
File
RR-7475.pdf
Identifiers
Citation
Alfonso Caiazzo, Miguel Angel Fernández, Vincent Martin. Analysis of a stabilized finite element method for fluid flows through a porous interface. Applied Mathematics Letters, 2011, 24 (12), pp.2124-2127. ⟨10.1016/j.aml.2011.06.012⟩. ⟨inria-00543014⟩
Share
Metrics
Record views
317
Files downloads
222
