MUDPACK: Multigrid Fortran Software for the Efficient Solution of Linear Elliptic Partial Differential Equations, Appl. Math. Comp, vol.34, pp.113-146, 1989. ,
Multiscale modelling of the respiratory tract, vol.3, pp.59-93, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00343629
Rates of convergence for viscous splitting of the Navier-Stokes equations, Math. Comp, vol.37, pp.243-259, 1981. ,
A finite element model of tracheal collapse, J. Appl. Physiol, vol.64, pp.1359-1368, 1988. ,
Numerical study of slightly viscous flow, J. Fluid Mech, vol.57, pp.785-796, 1973. ,
Numerical solution of hydrodynamics by the method of point vortices, J. Comp. Phys, vol.13, pp.363-379, 1973. ,
A computational model of Navier-Stokes equations with imposed pressure and velocity fluxes, Int. J. Numer. Methods in Fluids, vol.20, pp.267-287, 1995. ,
A vortex level set method for the two-way coupling of an incompressible fluid with colliding rigid bodies, J. Comp. Phys, vol.227, pp.9121-9137, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00297673
Surfactant transport on mucus films, J. Fluid Mech, vol.425, pp.235-358, 2000. ,
An image-based computational model of oscillatory flow in the proximal part of tracheobronchial trees, Comp. Meth. Biomech. Biomed. Eng, vol.8, issue.4, pp.279-293, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00273054
A fast algorithm for particle simulation, J. Comp. Phys, vol.73, pp.325-348, 1987. ,
Spatially distributed control for optimal drag reduction in cylinder wakes, J. Fluid Mech, vol.599, pp.111-120, 2008. ,
Micro-and macrorheology of mucus, Adv. Drug Del. Rev, vol.61, pp.86-100, 2009. ,
Efficiency of multiscale hybrid grid-particle vortex methods ,
URL : https://hal.archives-ouvertes.fr/hal-02010647
Analysis of an immersed boundary method for three-dimensional flows in vorticity formulation, J. Comp. Phys, vol.228, pp.7268-7288, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-02010649
Analysis of direct three-dimensional parabolic panel methods, SIAM J. Numer. Anal, vol.45, pp.2259-2297, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-02010650
Topological aspects of the three-dimensional wake behind rotary oscillating circular cylinder, J. Fluid Mech, vol.517, pp.27-53, 2004. ,
Vorticity interaction mechanisms in variable-viscosity heterogeneous miscible displacements with and without density contrast, J. Fluid Mech, vol.517, pp.1-25, 2004. ,
In vitro validation of CFD simulation in human proximal airways reconstructed from medical images with hyperpolarized helium-3 MRI phase contrast velocimetry, J. Appli. Physiol, vol.102, issue.5, pp.2012-2023, 2007. ,
A Parallel and Vector Variant of the Cyclic Reduction Algorithm, SIAM J. Sci. and Stat. Comp, vol.9, pp.761-766, 1988. ,
The effect on gas mixing of a He-O2 mixture in chronic obstructive lung diseases, Bull. Europ. Physio-path. Resp, vol.15, pp.1053-1068, 1982. ,
Experiments on flow limitation during forced expiration in a monoalveolar model, Med. Biol. Eng. Comput, vol.21, pp.681-687, 1983. ,
Banc d'analyse optique de la déformation de conduites souples, Innov. Tech. Biol. Med, vol.8, pp.99-107, 1986. ,
Experimental and theoretical models of flow during forced expiration. Pressure and pressure history dependence of flow rate, Med. Biol. Eng. Comp, vol.25, pp.551-559, 1987. ,
A pulsatile developing flow in a bend, J. Phys. III, vol.2, pp.995-1013, 1992. ,
URL : https://hal.archives-ouvertes.fr/jpa-00248799
Efficient Integration of Large Stiff Systems of ODEs with Exponential Propagation Iterative (EPI) Methods, J. Comp. Phys, vol.213, 2006. ,
Three-dimensional Model of the Structure and Evolution of the Coronal Mass Ejections, Astronom. J, vol.567, issue.2, p.1202, 2003. ,
