Audio source separation using sparse representations - Archive ouverte HAL Access content directly
Book Sections Year : 2010
(1) , (1) , (2) , (1)
1
2
We address the problem of audio source separation, namely, the recovery of audio signals from recordings of mixtures of those signals. The sparse component analysis framework is a powerful method for achieving this. Sparse orthogonal transforms, in which only few transform coefficients differ significantly from zero, are developed; once the signal has been transformed, energy is apportioned from each transform coefficient to each estimated source, and, finally, the signal is reconstructed using the inverse transform. The overriding aim of this chapter is to demonstrate how this framework, as exemplified here by two different decomposition methods which adapt to the signal to represent it sparsely, can be used to solve different problems in different mixing scenarios. To address the instantaneous (neither delays nor echoes) and underdetermined (more sources than mixtures) mixing model, a lapped orthogonal transform is adapted to the signal by selecting a basis from a library of predetermined bases. This method is highly related to the windowing methods used in the MPEG audio coding framework. In considering the anechoic (delays but no echoes) and determined (equal number of sources and mixtures) mixing case, a greedy adaptive transform is used based on orthogonal basis functions that are learned from the observed data, instead of being selected from a predetermined library of bases. This is found to encode the signal characteristics, by introducing a feedback system between the bases and the observed data. Experiments on mixtures of speech and music signals demonstrate that these methods give good signal approximations and separation performance, and indicate promising directions for future research.
nesbit_IGI10.pdf (255.53 Ko) Télécharger le fichier
Dates and versions
inria-00544030 , version 1 (10-12-2011)
Identifiers
Cite
Andrew Nesbit, Maria G. Jafari, Emmanuel Vincent, Mark D. Plumbley. Audio source separation using sparse representations. W. Wang. Machine Audition: Principles, Algorithms and Systems, IGI Global, pp.246--265, 2010, ⟨10.4018/978-1-61520-919-4.ch010⟩. ⟨inria-00544030⟩
267 View
696 Download
Share
