Multiple pitch transcription using DBN-based musicological models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a novel approach to solve the problem of estimating pitches of notes present in an audio signal. We have developed a probabilistically rigorous model that takes into account temporal dependencies between musical notes and between the underlying chords, as well as the instantaneous dependencies between chords, notes and the observed note saliences. We investigated its modeling ability by measuring the cross-entropy with symbolic (MIDI) data and then proceed to observe the model's performance in multiple pitch estimation of audio data.
raczynski_ISMIR10.pdf (524.17 Ko) Télécharger le fichier
inria-00544064 , version 1 (07-12-2010)
  • HAL Id : inria-00544064 , version 1
Stanislaw A. Raczynski, Emmanuel Vincent, Frédéric Bimbot, Shigeki Sagayama. Multiple pitch transcription using DBN-based musicological models. 2010 Int. Society for Music Information Retrieval Conf. (ISMIR), Aug 2010, Utrecht, Netherlands. pp.363--368. ⟨inria-00544064⟩
260 Consultations
145 Téléchargements
