Blind separation of convolved mixtures in the frequency domain, Neurocomputing, vol.22, issue.1-3, pp.21-34, 1998. ,
DOI : 10.1016/S0925-2312(98)00047-2
Blind source separation : statistical principles, Proceedings of the IEEE, vol.9, issue.10, pp.2009-2025, 1998. ,
DOI : 10.1109/5.720250
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.7237
Blind separation of instantaneous mixtures of nonstationary sources, IEEE Transactions on Signal Processing, vol.49, issue.9, pp.1837-1848, 2001. ,
DOI : 10.1109/78.942614
Multi-channel source separation by factorial HMMs, 2003 IEEE International Conference on Acoustics, Speech, and Signal Processing, 2003. Proceedings. (ICASSP '03)., pp.664-667, 2003. ,
DOI : 10.1109/ICASSP.2003.1198868
URL : http://academiccommons.columbia.edu/download/fedora_content/download/ac:148740/CONTENT/icassp03-fhmm.pdf
One microphone source separation, Advances in Neural Information Processing Systems (NIPS 13), pp.793-799, 2001. ,
Non negative sparse representation for Wiener based source separation with a single sensor, 2003 IEEE International Conference on Acoustics, Speech, and Signal Processing, 2003. Proceedings. (ICASSP '03)., pp.613-616, 2004. ,
DOI : 10.1109/ICASSP.2003.1201756
URL : https://hal.archives-ouvertes.fr/inria-00574784
Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
DOI : 10.1109/TSP.2004.828896
Speech segregation based on sound localization, The Journal of the Acoustical Society of America, vol.114, issue.4, pp.2236-2252, 2003. ,
DOI : 10.1121/1.1610463
Musical source separation using time-frequency source priors, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.1, pp.91-98, 2006. ,
DOI : 10.1109/TSA.2005.860342
URL : https://hal.archives-ouvertes.fr/inria-00544269
The fundamental limitation of frequency domain blind source separation for convolutive mixtures of speech, IEEE Transactions on Speech and Audio Processing, vol.11, issue.2, pp.109-116, 2003. ,
DOI : 10.1109/TSA.2003.809193
Experimental upper bound for the performance of convolutive source separation methods, IEEE Transactions on Signal Processing, vol.54, issue.2, pp.627-635, 2006. ,
DOI : 10.1109/TSP.2005.861766
Blind separation of real world audio signals using overdetermined mixtures, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.251-256, 1999. ,
Robustness of parametric source demixing in echoic environments, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.144-148, 2001. ,
On the FIR Inversion of an Acoustical Convolutive Mixing System: Properties and Limitations, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.643-651, 2004. ,
DOI : 10.1007/978-3-540-30110-3_82
Experimental Upper Bound for Convolutive Mixtures of Speech by Maximizing SIR, 2006 16th IEEE Signal Processing Society Workshop on Machine Learning for Signal Processing, pp.235-240, 2006. ,
DOI : 10.1109/MLSP.2006.275554
Minimal distortion principle for blind source separation, Proceedings of the 41st SICE Annual Conference. SICE 2002., pp.722-727, 2001. ,
DOI : 10.1109/SICE.2002.1195729
Audio source separation of convolutive mixtures, IEEE Transactions on Speech and Audio Processing, vol.11, issue.5, pp.489-497, 2003. ,
DOI : 10.1109/TSA.2003.815820
SIMO-model-based independent component analysis for high-fidelity blind separation of acoustic signals, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.993-998, 2003. ,
Evaluation of blind signal separation methods, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.261-266, 1999. ,
Performance measurement in blind audio source separation, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.4, pp.1462-1469, 2006. ,
DOI : 10.1109/TSA.2005.858005
URL : https://hal.archives-ouvertes.fr/inria-00544230
A new psychoacoustical masking model for audio coding applications, Proc. IEEE Int ,
Computational modelling and simulation of acoustic spaces, Proc. AES 22nd Conf. on Virtual, Synthetic and Entertainment Audio, pp.1-20, 2002. ,
Signal estimation from modified short-time Fourier transform, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.2, pp.236-243, 1984. ,
DOI : 10.1109/TASSP.1984.1164317
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.306.7858
Separation of speech signals with segmentation of the impulse responses under reverberant conditions, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.511-516, 2003. ,
Analysis/Synthesis filter bank design based on time domain aliasing cancellation, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.5, pp.1153-1161, 1986. ,
DOI : 10.1109/TASSP.1986.1164954
Reducing musical noise by a fineshift overlap-add method applied to source separation using a time-frequency mask, Proc. IEEE Int. Conf. on Acoustics, Speech and Signal Processing (ICASSP), pp.81-84, 2005. ,
Nonlinear Postprocessing for Blind Speech Separation, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.832-839, 2004. ,
DOI : 10.1007/978-3-540-30110-3_105
Underdetermined blind source separation of audio sources in time-frequency domain, Proc. Workshop on Signal Processing with Sparse/Structured Representations (SPARS), pp.67-70, 2005. ,
Underdetermined blind source separation using sparse representations, Signal Processing, vol.81, issue.11, pp.2353-2362, 2001. ,
DOI : 10.1016/S0165-1684(01)00120-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.3694
Generalized sparse signal mixing model and application to noisy blind source separation, 2004 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.877-880, 2004. ,
DOI : 10.1109/ICASSP.2004.1326685
On real and complex valued l/sub 1/-norm minimization for overcomplete blind source separation, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, 2005., pp.86-89, 2005. ,
DOI : 10.1109/ASPAA.2005.1540175
Difficulty measures and figures of merit for source separation, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.133-138, 1999. ,
