S. Winter, H. Sawada, and S. Makino, On real and complex valued l1-norm minimization for overcomplete blind source separation, Proc. IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.86-89, 2005.
L. Vielva, D. Erdo?-gmu¸sgmu¸s, and J. C. Príncipe, Underdetermined blind source separation using a probabilistic source sparsity model, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.675-679, 2001.
M. E. Davies and N. Mitianoudis, Simple mixture model for sparse overcomplete ICA, IEE Proceedings - Vision, Image, and Signal Processing, vol.151, issue.1, pp.35-43, 2004.
DOI : 10.1049/ip-vis:20040304
C. Févotte and S. J. Godsill, A Bayesian Approach for Blind Separation of Sparse Sources, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.6, pp.2174-2188, 2006.
DOI : 10.1109/TSA.2005.858523
T. W. Lee, M. S. Lewicki, M. A. Girolami, and T. J. Sejnowski, Blind source separation of more sources than mixtures using overcomplete representations, IEEE Signal Processing Letters, vol.6, pp.87-90, 1999.
M. Zibulevsky, B. A. Pearlmutter, P. Bofill, and P. Kisilev, Blind source separation by sparse decomposition in a signal dictionary. In: Independent Component Analysis : Principles and Practice, pp.181-208, 2001.
P. Bofill and E. Monte, Underdetermined Convoluted Source Reconstruction Using LP and SOCP, and a Neural Approximator of the Optimizer, Proc. Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), pp.569-576, 2006.
DOI : 10.1007/11679363_71
S. Choi, A. Cichocki, and S. Amari, Flexible independent component analysis, Neural Networks for Signal Processing, pp.83-92, 1998.
R. Everson and S. Roberts, Independent Component Analysis: A Flexible Nonlinearity and Decorrelating Manifold Approach, Neural Computation, vol.95, issue.2, pp.1957-1983, 1999.
DOI : 10.1090/conm/099/1034504
H. C. Wu and J. C. Príncipe, Generalized anti-Hebbian learning for source separation, Proc. IEEE Int. Conf. on Acoustics, Speech and Signal Processing, pp.1073-1076, 1999.
O. Y?lmaz and S. T. Rickard, Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004.
DOI : 10.1109/TSP.2004.828896
E. Vincent, R. Gribonval, and M. D. Plumbley, Oracle estimators for the benchmarking of source separation algorithms, Signal Processing, vol.87, issue.8, pp.1933-1950, 2007.
DOI : 10.1016/j.sigpro.2007.01.016
URL : https://hal.archives-ouvertes.fr/inria-00545156
A. Van-den-bos, Complex gradient and Hessian, IEE Proceedings on Vision, pp.380-382, 1994.
DOI : 10.1049/ip-vis:19941555
