Abstract : Polyphonic pitch transcription consists of estimating the onset time, duration and pitch of each note within a music signal. Adaptive signal models such as Nonnegative Matrix Factorization (NMF) appear well suited to this task, since they can provide a meaningful representation whatever instruments are playing. In this paper, we propose a simple transcription method using minimum residual loudness NMF, harmonic comb-based pitch identification and threshold-based onset/offset detection, and investigate a second method incorporating harmonicity constraints in the NMF model. Both methods are evaluated in the framework of MIREX 2007.
