13818-3:1998 : Information technology -generic coding of moving pictures and associated audio, part 3: Audio ,
14496-3:2005 Coding of audio-visual objects, part 3: Audio. MPEG-4 Audio, ISO/IEC International Standard, 2005. ,
Bandwidth Expansion of Narrowband Speech Using Non-Negative Matrix Factorization, Eurospeech 2005, 2005. ,
A tutorial on onset detection in music signals, IEEE Transactions on Speech and Audio Processing, vol.13, issue.5, 2005. ,
DOI : 10.1109/TSA.2005.851998
MP3 and AAC explained, Proceedings of AES 17th International Conference on High-Quality Audio Coding. AES, 1999. ,
A comparison of sound onset detection algorithms with emphasis on psychoacoustically motivated detection functions, Proceedings of AES 118th Convention. AES, 2005. ,
Object-based analysis-synthesis coding of image sequences at very low bit rates, IEEE Transactions on Circuits and Systems for Video Technology, pp.228-235, 1994. ,
DOI : 10.1109/76.305868
Lossless compression of digital audio, IEEE Signal Processing Magazine, vol.18, issue.4, pp.21-32, 2001. ,
DOI : 10.1109/79.939834
Methodology and tools for the evaluation of automatic onset detection algoritms in music, Proceedings of ISMIR 2004, the 5th International Conference on Music Information Retrieval, pp.72-75, 2004. ,
Object Coding for Real Time Image Processing Applications, In Pattern Recognition and Image Analysis Lecture Notes in Computer Science, vol.3687, pp.550-559, 2005. ,
DOI : 10.1007/11552499_61
Objectbased analysis/synthesis audio coder for very lowbit rates, Proceedings of AES 104th Convention. AES, 1998. ,
Speeding up HILN-MPEG-4 parametric audio encoding with reduced complexity, Proceedings of AES 109th Convention. AES, 2000. ,
SHORTEN: Simple lossless and nearlossless waveform compression, 1994. ,
An automatic algorithm for approximating boundary of bitmap characters, Future Generation Computer Systems, vol.20, issue.8, pp.1327-1336, 2004. ,
DOI : 10.1016/j.future.2004.05.024
Structured audio and effects processing in the mpeg-4 multimedia standard, Multimedia Systems, issue.7, pp.11-22, 1999. ,
Object-based sound source modeling for musical signals, Proceedings of 109th AES Convention -SESSION A: DIGITAL SIGNAL PROCESSING, PART 1, 2000. ,
Structured audio: creation, transmission, and rendering of parametric sound representations, Proceedings of the IEEE, pp.922-940, 1998. ,
DOI : 10.1109/5.664280
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.16.9475
Low Bitrate Object Coding of Musical Audio using Bayesian Harmonic Models, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00545579
