Rate-distortion optimal sinusoidal modeling of audio and speech using psychoacoustical matching pursuits, Proc. IEEE Int. Conf. on Acoustics, Speech and Signal Processing (ICASSP), pp.1809-1812, 2002. ,
Parametric coding for high-quality audio, Proc. AES 112th Convention, p.5554, 2002. ,
Transmitting audio content as sound objects, Proc. AES 22nd Conf. on Virtual, Synthetic and Entertainment Audio, pp.278-288, 2001. ,
Object-based analysis/synthesis audio coder for very low bit rates, Proc. AES 104th Convention, p.4747, 1998. ,
Audio object coding for distributed audio data management applications, The 8th International Conference on Communication Systems, 2002. ICCS 2002., pp.727-731, 2002. ,
DOI : 10.1109/ICCS.2002.1183222
Perceptually motivated parametric representation for harmonic sounds for data compression purposes, Proc. Int. Conf. on Digital Audio Effects (DAFx), pp.249-253, 2003. ,
Parametric audio coding, Proc. Int. Conf. on Signal Processing, pp.21-24, 2000. ,
A prototype system for object coding of musical audio, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, 2005., pp.239-242, 2005. ,
DOI : 10.1109/ASPAA.2005.1540214
URL : https://hal.archives-ouvertes.fr/inria-00544687
Speech analysis/Synthesis based on a sinusoidal representation, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.4, pp.744-754, 1986. ,
DOI : 10.1109/TASSP.1986.1164910
Computational auditory scene analysis, Computer Speech & Language, vol.8, issue.4, pp.297-336, 1994. ,
DOI : 10.1006/csla.1994.1016
Prediction-driven computational auditory scene analysis, 1996. ,
A computationally efficient multipitch analysis model, IEEE Transactions on Speech and Audio Processing, vol.8, issue.6, pp.708-716, 2000. ,
DOI : 10.1109/89.876309
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.334.1573
Harmonic decomposition of audio signals with matching pursuit, IEEE Transactions on Signal Processing, vol.51, issue.1, pp.101-111, 2003. ,
DOI : 10.1109/TSP.2002.806592
URL : https://hal.archives-ouvertes.fr/inria-00576203
Polyphonic pitch tracking using joint Bayesian estimation of multiple frame parameters, Proceedings of the 1999 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics. WASPAA'99 (Cat. No.99TH8452), pp.119-122, 1999. ,
DOI : 10.1109/ASPAA.1999.810864
Bayesian analysis of polyphonic western tonal music, The Journal of the Acoustical Society of America, vol.119, issue.4, pp.2498-2517, 2006. ,
DOI : 10.1121/1.2168548
URL : https://hal.archives-ouvertes.fr/inria-00120240
A generative model for music transcription, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.2, pp.679-694, 2006. ,
DOI : 10.1109/TSA.2005.852985
Modèles d'instruments pour la séparation de sources et la transcription d'enregistrements musicaux, Ph.D. dissertation, IRCAM, 2004. ,
A new psycho-acoustical masking model for audio coding applications, Proc. IEEE Int. Conf. on Acoustics, Speech and Signal Processing (ICASSP), pp.1805-1808, 2002. ,
Derivation of auditory filter shapes from notched-noise data, Hearing Research, vol.47, issue.1-2, pp.103-138, 1990. ,
DOI : 10.1016/0378-5955(90)90170-T
Psychoacoustics: Facts and Models, 2nd Edition, 1999. ,
DOI : 10.1007/978-3-662-09562-1
Efficient approximations for the marginal likelihood of Bayesian networks with hidden variables, Proc. Conf. on Uncertainty in Artificial Intelligence (UAI), pp.158-168, 1996. ,
Spectrum interpolation synthesis for the compression of musical signals, Proc. Int. Conf. on Digital Audio Effects (DAFx), pp.184-188, 2001. ,
1534-1: Method for the subjective assessment of intermediate quality levels of coding systems, 2003. ,
Sinusoidal coding using loudness-based component selection, IEEE International Conference on Acoustics Speech and Signal Processing, pp.1817-1820, 2002. ,
DOI : 10.1109/ICASSP.2002.5744977
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.20.5920
A comparison of differential schemes for low-rate sinusoidal audio coding, 2003 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (IEEE Cat. No.03TH8684), pp.205-208, 2003. ,
DOI : 10.1109/ASPAA.2003.1285867
Predominant-F0 estimation using bayesian harmonic waveform models, Proc. Music Information Retrieval Evaluation eXchange (MIREX), 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00544667
