Approximate Boolean operations on free-form solids, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.185-194, 2001. ,
DOI : 10.1145/383259.383280
Cutand-paste editing of multiresolution surfaces, Proceedings of SIGGRAPH 02, 2002. ,
Sharp Features on Multiresolution Subdivision Surfaces, Graphical Models, vol.64, issue.2, pp.61-77, 2002. ,
DOI : 10.1006/gmod.2002.0570
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.91.8675
Recursively generated B-spline surfaces on arbitrary topological meshes, Computer-Aided Design, vol.10, issue.6, pp.350-355, 1978. ,
DOI : 10.1016/0010-4485(78)90110-0
Deformable curve and surface finite-elements for freeform shape design, Proceedings of SIGGRAPH 91, pp.257-265, 1991. ,
Splines minimizing rotation-invariant seminorms in Sobolev spaces, 1977. ,
Hierarchical and variational geometric modeling with wavelets, Proceedings of the 1995 symposium on Interactive 3D graphics , SI3D '95, 1995. ,
DOI : 10.1145/199404.199410
Variational Design and Fairing of Spline Surfaces, Computer Graphics Forum, vol.13, issue.3, pp.143-154, 1994. ,
DOI : 10.1111/1467-8659.1330143
Multi-Grid Methods and Applications, 1985. ,
DOI : 10.1007/978-3-662-02427-0
Efficient Techniques for Surface Design Using Constrained Optimization, 1996. ,
Efficient, fair interpolation using Catmull-Clark surfaces, Proceedings of the 20th annual conference on Computer graphics and interactive techniques , SIGGRAPH '93, pp.35-44, 1993. ,
DOI : 10.1145/166117.166121
Constrained Optimization in Surface Design, 1993. ,
DOI : 10.1007/978-3-642-78114-8_5
Multiresolution Shape Deformations for Meshes with Dynamic Vertex Connectivity, Proceedings of Eurographics 00, pp.249-260, 2000. ,
DOI : 10.1111/1467-8659.00417
A multiresolution framework for variational subdivision, ACM Transactions on Graphics, vol.17, issue.4, pp.209-237, 1998. ,
DOI : 10.1145/293145.293146
Discrete fairing and variational subdivision for freeform surface design. The Visual Computer, pp.3-4142, 2000. ,
Polyhedra surface modeling with a diffusion system, Proceedings of Eurographics 97, pp.39-46, 1997. ,
The Variational Principles of Mechanics, 1986. ,
Multiresolution analysis for surfaces of arbitrary topological type, ACM Transactions on Graphics, vol.16, issue.1, pp.34-73, 1997. ,
DOI : 10.1145/237748.237750
Multivariate interpolation at arbitrary points made simple, Zeitschrift f??r angewandte Mathematik und Physik ZAMP, vol.10, issue.2, pp.292-304, 1979. ,
DOI : 10.1007/BF01601941
Minimum Curvature Variation Curves, Networks , and Surfaces for Fair Free-Form Shape Design, 1993. ,
Functional optimization for fair surface design, Proceedings of SIGGRAPH 92, pp.167-176, 1992. ,
A multilevel approach to surface response in dynamically deformable models, Proceedings of Computer Animation '94, pp.21-30, 1994. ,
DOI : 10.1109/CA.1994.324010
Hierarchical editing and rendering of subdivision surfaces, 1997. ,
Variational design of curves and surfaces using multiresolution constraints. The Visual Computer, pp.208-227, 1998. ,
Multiresolution constraints for designing subdivision surfaces via local smoothing, Proceedings. Seventh Pacific Conference on Computer Graphics and Applications (Cat. No.PR00293), pp.168-178, 1999. ,
DOI : 10.1109/PCCGA.1999.803360
Elastically deformable models, Proceedings of SIGGRAPH 87, pp.205-214, 1987. ,
Variational modeling of triangular bezier surfaces ,
A comparison of invarian energies for free-form surface construction. The Visual Computer, pp.199-210, 1999. ,
Draft: Subdivision schemes for variational splines ,
Subdivision Schemes for Physical Problems, 2000. ,
Subdivision Schemes for Thin Plate Splines, Proceedings of Eurographics 98, pp.303-313, 1998. ,
DOI : 10.1111/1467-8659.00277
Variational surface modeling, Computer Graphics (SIGGRAPH '92 Proceedings), volume, pp.157-166, 1992. ,
DOI : 10.1145/133994.134033
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.27.5545
Interactive multiresolution mesh editing, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, pp.259-268, 1997. ,
DOI : 10.1145/258734.258863
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.1147
