Application of Geometric Dependency Analysis to the Separation of Convolved Mixtures, Independent Component Analysis and Blind Signal Separation: Proceedings of the Fifth International Conference, pp.540-547, 2004. ,
DOI : 10.1007/978-3-540-30110-3_69
Polyphonic transcription by non-negative sparse coding of power spectra, Proceedings of the 5th International Conference on Music Information Retrieval, pp.318-325, 2004. ,
Unsupervised Analysis of Polyphonic Music by Sparse Coding, IEEE Transactions on Neural Networks, vol.17, issue.1, pp.179-196, 2006. ,
DOI : 10.1109/TNN.2005.861031
An Information-Maximization Approach to Blind Separation and Blind Deconvolution, Neural Computation, vol.20, issue.1, pp.1129-1159, 1995. ,
DOI : 10.1109/78.301850
Towards the Automated Analysis of Simple Polyphonic Music: A Knowledge-Based Approach, 2003. ,
Unsupervised learning of sparse and shiftinvariant decompositions of polyphonic music, Proceedings of the IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.497-500, 2004. ,
Underdetermined blind source separation using sparse representations, Signal Processing, vol.81, issue.11, pp.2353-2362, 2001. ,
DOI : 10.1016/S0165-1684(01)00120-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.3694
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1998. ,
DOI : 10.1137/S1064827596304010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.113.7694
Prediction-Driven Computational Auditory Scene Analysis, 1996. ,
What Is the Goal of Sensory Coding?, Neural Computation, vol.21, issue.4, pp.559-601, 1994. ,
DOI : 10.1162/neco.1989.1.1.68
Adaptive sparseness for supervised learning, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.9, pp.1150-1159, 2003. ,
DOI : 10.1109/TPAMI.2003.1227989
On Sparse Representations in Arbitrary Redundant Bases, IEEE Transactions on Information Theory, vol.50, issue.6, pp.1341-1344, 2004. ,
DOI : 10.1109/TIT.2004.828141
Sparse signal reconstruction from limited data using FOCUSS: a re-weighted minimum norm algorithm, IEEE Transactions on Signal Processing, vol.45, issue.3, pp.600-616, 1997. ,
DOI : 10.1109/78.558475
Sparse representations in unions of bases, IEEE Transactions on Information Theory, vol.49, issue.12, pp.3320-3325, 2003. ,
DOI : 10.1109/TIT.2003.820031
URL : https://hal.archives-ouvertes.fr/inria-00570057
Non-negative sparse coding, Proceedings of the 12th IEEE Workshop on Neural Networks for Signal Processing, pp.557-565, 2002. ,
DOI : 10.1109/NNSP.2002.1030067
Sparse Code Shrinkage: Denoising of Nongaussian Data by Maximum Likelihood Estimation, Neural Computation, vol.58, issue.7, pp.1739-1768, 1999. ,
DOI : 10.1016/S0042-6989(97)00169-7
Sparse Coding for Convolutive Blind Audio Source Separation, Proceedings of the 6th International Conference on Independent Component Analysis and Blind Source Separation, pp.132-139, 2006. ,
DOI : 10.1007/11679363_17
Blind separation of disjoint orthogonal signals: demixing N sources from 2 mixtures, 2000 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.00CH37100), pp.2985-2988, 2000. ,
DOI : 10.1109/ICASSP.2000.861162
Dictionary Learning Algorithms for Sparse Representation, Neural Computation, vol.15, issue.2, pp.349-396, 2003. ,
DOI : 10.1162/089976601300014385
Learning the parts of objects by non-negative matrix factorization, Nature, vol.401, pp.788-791, 1999. ,
Learning Overcomplete Representations, Neural Computation, vol.33, issue.2, pp.337-365, 2000. ,
DOI : 10.1109/18.119725
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.164.7690
Sound-Source Recognition: A Theory and Computational Model, 1999. ,
Source extraction from two-channel mixtures by joint cosine packet analysis, 2006. ,
Survey of sparse and non-sparse methods in source separation, International Journal of Imaging Systems and Technology, vol.47, issue.33, pp.18-33, 2005. ,
DOI : 10.1002/ima.20035
Emergence of simple-cell receptive field properties by learning a sparse code for natural images, Nature, vol.381, issue.6583, pp.607-609, 1996. ,
DOI : 10.1038/381607a0
Sparse coding of sensory inputs, Current Opinion in Neurobiology, vol.14, issue.4, pp.481-487, 2004. ,
DOI : 10.1016/j.conb.2004.07.007
Automatic Music Transcription and Audio Source Separation, Cybernetics and Systems, vol.84, issue.6, pp.603-627, 2002. ,
DOI : 10.1162/neco.1995.7.1.51
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.6930
Sparse representations of polyphonic music, Signal Processing, vol.86, issue.3, pp.417-431, 2006. ,
DOI : 10.1016/j.sigpro.2005.06.007
Non-negative Matrix Factor Deconvolution; Extraction of Multiple Sound Sources from Monophonic Inputs, Independent Component Analysis and Blind Signal Separation: Proceedings of the Fifth International Conference, pp.494-499, 2004. ,
DOI : 10.1007/978-3-540-30110-3_63
Regression shrinkage and selection via the lasso, J. Royal. Statist. Soc B, vol.58, issue.1, pp.267-288, 1996. ,
Blind audio source separation, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00544230
Separation of sound sources by convolutive sparse coding, Proceedings of the ISCA Tutorial and Research Workshop on Statistical and Perceptual Audio Processing, 2004. ,
Musical audio stream separation by non-negative matrix factorization, Proceedings of the DMRN Summer Conference, pp.23-24, 2005. ,
