Single-channel mixture decomposition using Bayesian harmonic models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Emmanuel Vincent
We consider the source separation problem for single-channel music signals. After a brief review of existing methods, we focus on decomposing a mixture into components made of harmonic sinusoidal partials. We address this problem in the Bayesian framework by building a probabilistic model of the mixture combining generic priors for harmonicity, spectral envelope, note duration and continuity. Experiments suggest that the derived blind decomposition method leads to better separation results than nonnegative matrix factorization for certain mixtures.
vincent_ICA06.pdf (100.43 Ko) Télécharger le fichier
inria-00544663 , version 1 (08-12-2010)
  • HAL Id : inria-00544663 , version 1
Emmanuel Vincent, Mark D. Plumbley. Single-channel mixture decomposition using Bayesian harmonic models. 6th Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), Mar 2006, Charleston, United States. pp.722--730. ⟨inria-00544663⟩
31 Consultations
191 Téléchargements
