Semantics-Preserving Implementation of Synchronous Specifications Over Dynamic TDMA Distributed Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a technique to automatically synthesize programs and schedules for hard real-time distributed (embedded) systems from synchronous data-flow models. Our technique connects the SynDEx scheduling tool and the Network Code toolchain in a seamless flow of automatic model transformations that go all the way from specification to implementation. Our contribution is the non-trivial connection between the models manipulated by SynDEx and by the Network Code toolchain, at both formal and tool level. We provide an algorithm for converting the data-dependent schedule tables output by SynDEx into Network Code programs which can be seen as an ``assembly code'' level for time-driven distributed real-time systems. The main difficulty is to ensure the preservation of both functionality and the real-time guarantees computed by SynDEx in the presence of clock drifts (which are abstracted away in the scheduling model of SynDEx). Existing tools can convert the resulting Network Code programs into software and hardware-accelerated execution units.
Nous proposons une technique pour la synthèse automatique de programmes et ordonnancements pour des systèmes temps-réel (embarqués) distribués, à partir de spécifications synchrones flot de données.
final-version.pdf (215.01 Ko) Télécharger le fichier
inria-00544665 , version 1 (08-12-2010)
Dumitru Potop-Butucaru, Akramul Azim, Sebastian Fischmeister. Semantics-Preserving Implementation of Synchronous Specifications Over Dynamic TDMA Distributed Architectures. International Conference on Embedded Software (EMSOFT), Oct 2010, Scottsdale, AZ, United States. pp.199-208, ⟨10.1145/1879021.1879048⟩. ⟨inria-00544665⟩
318 Consultations
185 Téléchargements
