Atoms of all channels, unite! Average case analysis of multi-channel sparse recovery using greedy algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fourier Analysis and Applications Année : 2008
This paper provides new results on computing simultaneous sparse approximations of multichannel signals over redundant dictionaries using two greedy algorithms. The first one, p-thresholding, selects the S atoms that have the largest p-correlation while the second one, p-simultaneous matching pursuit (p-SOMP), is a generalisation of an algorithm studied by Tropp in (Signal Process. 86:572–588, 2006). We first provide exact recovery conditions as well as worst case analyses of all algorithms. The results, expressed using the standard cumulative coherence, are very reminiscent of the single channel case and, in particular, impose stringent restrictions on the dictionary. We unlock the situation by performing an average case analysis of both algorithms. First, we set up a general probabilistic signal model in which the coefficients of the atoms are drawn at random from the standard Gaussian distribution. Second, we show that under this model, and with mild conditions on the coherence, the probability that p-thresholding and p-SOMP fail to recover the correct components is overwhelmingly small and gets smaller as the number of channels increases. Furthermore, we analyse the influence of selecting the set of correct atoms at random. We show that, if the dictionary satisfies a uniform uncertainty principle (Candes and Tao, IEEE Trans. Inf. Theory, 52(12):5406–5425, 2006), the probability that simultaneous OMP fails to recover any sufficiently sparse set of atoms gets increasingly smaller as the number of channels increases.
2008_JFAA_AverageGreed.pdf (311.44 Ko) Télécharger le fichier
inria-00544761 , version 1 (07-02-2011)
Rémi Gribonval, Holger Rauhut, Karin Schnass, Pierre Vandergheynst. Atoms of all channels, unite! Average case analysis of multi-channel sparse recovery using greedy algorithms. Journal of Fourier Analysis and Applications, 2008, 14 (5), pp.655--687. ⟨10.1007/s00041-008-9044-y⟩. ⟨inria-00544761⟩
2804 Consultations
385 Téléchargements
