Average Case Analysis of Multichannel Thresholding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Karin Schnass
  • Fonction : Auteur
  • PersonId : 884521
Pierre Vandergheynst
  • Fonction : Auteur
  • PersonId : 839985
This paper introduces p-thresholding, an algorithm to compute simultaneous sparse approximations of multichannel signals over redundant dictionaries. We work out both worst case and average case recovery analyses of this algorithm and show that the latter results in much weaker conditions on the dictionary. Numerical simulations confirm our theoretical findings and show that p-thresholding is an interesting low complexity alternative to simultaneous greedy or convex relaxation algorithms for processing sparse multichannel signals with balanced coefficients.
DCSicassp07.pdf (175.34 Ko) Télécharger le fichier
inria-00544776 , version 1 (07-02-2011)
Rémi Gribonval, Boris Mailhé, Holger Rauhut, Karin Schnass, Pierre Vandergheynst. Average Case Analysis of Multichannel Thresholding. Acoustics, Speech and Signal Processing, 2007. ICASSP 2007. IEEE International Conference on, Apr 2007, Honolulu, Hawai, United States. pp.II-853 - II-856, ⟨10.1109/ICASSP.2007.366370⟩. ⟨inria-00544776⟩
298 Consultations
171 Téléchargements
