Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, pp.1830-1847, 2002. ,
DOI : 10.1109/TSP.2004.828896
Blind separation of dependent sources using the " time-frequency ratio of mixtures " approach, ISSPA 2003, 2003. ,
A time-frequency correlationbased blind source separation method for time-delayed mixtures, ICASSP, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00289305
Underdetermined blind source separation using sparse representations, Signal Processing, pp.2353-2362, 2001. ,
A Robust Method to Count and Locate Audio Sources in a Stereophonic Linear Instantaneous Mixture, ICA, 2006. ,
DOI : 10.1007/11679363_67
URL : https://hal.archives-ouvertes.fr/inria-00544925
The generalized correlation method for estimation of time delay, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.4 ,
DOI : 10.1109/TASSP.1976.1162830
Personal use of this material is permitted. Permission from IEEE must be obtained for all other users, including reprinting/republishing this material for advertising or promotional purposes, creating new collective works for resale or redistribution to servers or lists, or reuse of any copyrighted components of this work in other works, IEEE, vol.24, issue.4, pp.320-327, 1976. ,
