Nonlinear approximation with dictionaries. II. Inverse estimates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Constructive Approximation Année : 2006
In this paper, which is the sequel to [R. Gribonval and M. Nielsen. Nonlinear approximation with dictionaries. I. Direct estimates. J. Fourier Anal. Appl., 10(1):51-71, 2004], we study inverse esti- mates of the Bernstein type for nonlinear approximation with structured redun- dant dictionaries in a Banach space. The main results are for blockwise incoherent dictionaries in Hilbert spaces, which generalize the notion of joint block-diagonal mutually incoherent bases introduced by Donoho and Huo. The Bernstein inequal- ity obtained for such dictionaries is proved to be sharp, but it has an exponent that does not match that of the corresponding Jackson inequality.
2006_CA_NLinverse.pdf (263.62 Ko) Télécharger le fichier
inria-00544906 , version 1 (08-02-2011)
Rémi Gribonval, Morten Nielsen. Nonlinear approximation with dictionaries. II. Inverse estimates. Constructive Approximation, 2006, 24 (2), pp.157--173. ⟨10.1007/s00365-005-0621-x⟩. ⟨inria-00544906⟩
201 Consultations
220 Téléchargements
