Partial Characterization of Synchronization Languages
Synchronization languages are associated with synchronization expressions, a high-level construct which allows a programmer to express synchronization constraints in a distributed context. We give a negative answer to a conjecture enunciated by L. Guo, K. Salomaa and S. Yu which aims at characterizing synchronization languages in terms of regular languages closed under a rewriting system. Then we propose an extension of the system which gives a positive answer for a class of regular languages.
