Audiovisual-based hypermedia authoring - using structured representations for efficient access to av documents. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
In this article we introduce the notion of audiovisualbased hypermedia authoring systems, i.e. systems mainly using documents from digital audiovisual (AV) archives as a source for hypermedia authoring. After showing that traditional hypermedia models are ill-designed for specific constraints implied by such systems, we propose a change of approach. We present a model based on formal structured representations of the content of documents as it is done in the field of structured documents. Since a specific mode1 for the representation of AV content is needed. we introduce Audiovisual Event Description Inter$ace (AEDI), which provides a model for the description of AV documents. and an XML-based syntax for the exchange of such descriptions. We describe AEDI's main concepts, how it can be related to a formal specification of the domain knowledge -called onrofogy - which allows efficient dynamic hyperlinking among elements. Finally, we describe the implementation of this mode1 for the production of AV based hypermedia at INA's production department.
Fichier non déposé
inria-00545189 , version 1 (11-09-2014)
Gwendal Auffret, Jean Carrive, Olivier Chevet, Thomas Dechilly, Rémi Ronfard, et al.. Audiovisual-based hypermedia authoring - using structured representations for efficient access to av documents.. Hypertext, ACM, 1999, Darmstadt, Germany. pp.169-178, ⟨10.1145/294469.294620⟩. ⟨inria-00545189⟩
161 Consultations
0 Téléchargements
