On the Use of an Iterative Estimation of Continuous Probabilistic Transforms for Voice Conversion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Voice conversion is a technique that modifies a source speaker's speech to be perceived as if a target speaker had spoken it. Among the algorithms of conversion published in the literature, the techniques using GMM are nowadays the reference. In this paper, we focus on a new technique for estimating parameters of the conversion function. We show that it is possible to determinate these parameters without statistical estimation using the classical Expectation Minimization (EM) algorithm. We propose a new method for determining the conversion function parameters. The technique proposed is based on an iterative statistical refinement algorithm working directly from data. The consequence of this strategy is that the estimation of the conversion function is very fast.
Fichier non déposé
inria-00545428 , version 1 (10-12-2010)
A. Werghi, Joseph Di Martino, S. Ben Jebara. On the Use of an Iterative Estimation of Continuous Probabilistic Transforms for Voice Conversion. 5th International Symposium on I/V Communications over fixed and Mobile Networks - ISIVC 2010, Sep 2010, Rabat, Morocco. pp.1-4, ⟨10.1109/ISVC.2010.5656149⟩. ⟨inria-00545428⟩
139 Consultations
0 Téléchargements
