Modeling and Analysis of Elliptic Coordination by Dynamic Exploitation of Derivation Forests in LTAG Parsing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Djamé Seddah
Benoît Sagot
In this paper, we introduce a generic approach to elliptic coordination modeling through the parsing of Ltag grammars. We show that erased lexical items can be replaced during parsing by informations gathered in the other member of the coordinate structure and used as a guide at the derivation level. Moreover, we show how this approach can be indeed implemented as a light extension of the LTAG formalism throuh a so-called fusion operation and by the use of tree schemata during parsing in order to obtain a dependency graph. 1
TAG06.pdf (105.7 Ko) Télécharger le fichier
inria-00545430 , version 1 (10-12-2010)
  • HAL Id : inria-00545430 , version 1
Djamé Seddah, Benoît Sagot. Modeling and Analysis of Elliptic Coordination by Dynamic Exploitation of Derivation Forests in LTAG Parsing. Proceedings of TAG+8 : The Eighth International Workshop on Tree Adjoining Grammar and Related Formalisms, 2006, Sydney, Australia. ⟨inria-00545430⟩
Collections
INRIA INRIA2
54 Consultations
48 Téléchargements
