Mining monolingual and bilingual corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Intelligent Data Analysis Année : 2010
In this paper, we describe two new methods of mining monolingual and bilingual text corpora that heavily rely on the use of association rules and triggers. The association rules based method is firstly applied in query expansion. The conducted experiments on French newspapers and on a set of scientific documents show that the proposed approach outperforms the baseline model. The second method focuses on the machine translation and is motivated by the results of triggers on statistical language modeling. In order to build up a translation table, association rules and triggers are then generalized to mine bilingual corpora. In this respect, we propose respectively the concepts of inter-lingual association rules and inter-lingual triggers. Both methods have been integrated in a real statistical machine translation. Carried out experiments highlight the practical feasibility of the introduced approaches in the context of machine translation and show that inter-lingual triggers achieve better results than those obtained using the third IBM model.
Revue2-13.pdf (318.02 Ko) Télécharger le fichier
inria-00545493 , version 1 (21-11-2017)
  • HAL Id : inria-00545493 , version 1
Chiraz Latiri, Kamel Smaïli, Caroline Lavecchia, David Langlois. Mining monolingual and bilingual corpora. Intelligent Data Analysis, 2010, 14 (6), pp.663-682. ⟨inria-00545493⟩
267 Consultations
138 Téléchargements
