A symbolic method to analyse patterns in plant structure whose organogenesis is driven by a multitype branching process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Formal grammars like L-systems have long been used to describe plant growth dynamics. In this article, they are used for a new purpose. The aim is to build a symbolic method derived from computer science that enables the computation of the distribution associated to the number of complex structures in plants whose organogenesis is driven by a multitype branching process. To that purpose, a new combinatorial framework is set in which plant structure is coded by a Dyck word. Moreover, the organogenesis is represented by stochastic F0L-systems. By doing so, the problem is equivalent to determining the distribution of patterns in random words generated by stochastic F0L-system. This method leads directly to numerous applications like parametric identication for plant growth model.
JCST_LOI_final.pdf (858.66 Ko) Télécharger le fichier
inria-00546309 , version 1 (15-12-2010)
  • HAL Id : inria-00546309 , version 1
Cedric Loi, Paul-Henry Cournède, Jean Françon. A symbolic method to analyse patterns in plant structure whose organogenesis is driven by a multitype branching process. 2010. ⟨inria-00546309⟩
285 Consultations
164 Téléchargements
