Modeling and simulation of fish like swimming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2011
Modeling and simulation of two-dimensional flows past deformable bodies are considered. The incompressible Navier–Stokes equations are discretized in space onto a fixed cartesian mesh and the displacement of deformable objects through the fluid is taken into account using a penalization method. The interface between the solid and the fluid is tracked using a level-set description so that it is possible to simulate several bodies freely evolving in the fluid. As an illustration of the methods, fish-like locomotion is analyzed in terms of propulsion efficiency. Underwater maneuvering and school swimming are also explored.
inria-00546330 , version 1 (14-12-2010)
Michel Bergmann, Angelo Iollo. Modeling and simulation of fish like swimming. Journal of Computational Physics, 2011, 230 (2), pp.329-348. ⟨10.1016/j.jcp.2010.09.017⟩. ⟨inria-00546330⟩
87 Consultations
0 Téléchargements
