Spatiotemporal energy models for the perception of motion, Journal of the Optical Society of America A, vol.2, issue.2, pp.284-299, 1985. ,
DOI : 10.1364/JOSAA.2.000284
Functional connectivity between simple cells and complex cells in cat striate cortex, Nature Neuroscience, vol.1, issue.5, pp.395-403, 1998. ,
DOI : 10.1038/1609
Energy and phase orientation mechanisms: a computational model, Spatial Vision, vol.15, issue.4, pp.415-441, 2002. ,
DOI : 10.1163/156856802320401892
Geometrical Computations Explain Projection Patterns of Long-Range Horizontal Connections in Visual Cortex, Neural Computation, vol.6, issue.4, pp.445-476, 2004. ,
DOI : 10.1162/neco.1989.1.1.68
Slow feature analysis yields a rich repertoire of complex cell properties, Journal of Vision, vol.5, issue.6, pp.579-602, 2005. ,
DOI : 10.1167/5.6.9
Probabilistic Interpretation of Feedforward Classification Network Outputs, with Relationships to Statistical Pattern Recognition, Neuro-computing: Algorithms, Architectures and Applictions, 1989. ,
DOI : 10.1007/978-3-642-76153-9_28
A computational approach to edge detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.6, pp.679-698, 1986. ,
What simple and complex cells compute, The Journal of Physiology, vol.38, issue.2, pp.463-466, 2006. ,
DOI : 10.1113/jphysiol.2006.118976
Do We Know What the Early Visual System Does?, Journal of Neuroscience, vol.25, issue.46, pp.10577-10597, 2005. ,
DOI : 10.1523/JNEUROSCI.3726-05.2005
Linearity and Normalization in Simple Cells of the Macaque Primary Visual Cortex, J. Neuroscience, issue.21, pp.178621-8644, 1997. ,
Complex cells as cortically amplified simple cells, Nature Neuroscience, vol.2, issue.3, pp.277-282, 1999. ,
Uncertainty relation for resolution in space, spatial frequency, and orientation optimized by two-dimensional visual cortical filters, Journal of the Optical Society of America A, vol.2, issue.7, 1985. ,
DOI : 10.1364/JOSAA.2.001160
Theoretical Neuroscience, 2001. ,
Endstopped neurons in the visual cortex as a substrate for calculating curvature, Nature, vol.329, issue.6138, pp.438-441, 1987. ,
DOI : 10.1038/329438a0
Directionally selective complex cells and the computation of motion energy in cat visual cortex, Vision Research, vol.32, issue.2, pp.203-218, 1992. ,
DOI : 10.1016/0042-6989(92)90130-B
The monogenic signal, IEEE Transactions on Signal Processing, vol.49, issue.12, pp.3136-3144, 2001. ,
DOI : 10.1109/78.969520
Neural Mechanisms of Orientation Selectivity in the Visual Cortex, Annual Review of Neuroscience, vol.23, issue.1, pp.441-471, 2000. ,
DOI : 10.1146/annurev.neuro.23.1.441
Neural encoding of binocular disparity: Energy models, position shifts and phase shifts, Vision Research, vol.36, issue.12, pp.1839-1857, 1996. ,
DOI : 10.1016/0042-6989(95)00313-4
Learning Invariance from Transformation Sequences, Neural Computation, vol.88, issue.2, pp.194-200, 1991. ,
DOI : 10.1088/0954-898X/2/1/003
The design and use of steerable filters, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.9, pp.891-906, 1991. ,
DOI : 10.1109/34.93808
Diversity of complex cell responses to even- and odd-symmetric luminance profiles in the visual cortex of the cat, Experimental Brain Research, vol.68, issue.2, pp.249-259, 1987. ,
DOI : 10.1007/BF00248791
From filters to features: Scale???space analysis of edge and blur coding in human vision, Journal of Vision, vol.7, issue.13, pp.1-21, 2007. ,
DOI : 10.1167/7.13.7
A Combined Corner and Edge Detector, Procedings of the Alvey Vision Conference 1988, pp.147-151, 1988. ,
DOI : 10.5244/C.2.23
Spatial Properties of Neurons in the Monkey Striate Cortex, Proceedings of the Royal Society B: Biological Sciences, vol.231, issue.1263, pp.251-288, 1987. ,
DOI : 10.1098/rspb.1987.0044
Optical flow using spatiotemporal filters, International Journal of Computer Vision, vol.300, issue.5892, pp.279-302, 1988. ,
DOI : 10.1007/BF00133568
Abstract, Visual Neuroscience, vol.296, issue.05, pp.427-443, 1992. ,
DOI : 10.1007/BF00238196
Linear and nonlinear spatial subunits in Y cat retinal ganglion cells., The Journal of Physiology, vol.262, issue.2, pp.265-284, 1976. ,
DOI : 10.1113/jphysiol.1976.sp011595
Receptive fields, binocular interaction and functional architecture in the cat's visual cortex, The Journal of Physiology, vol.160, issue.1, pp.106-54, 1962. ,
DOI : 10.1113/jphysiol.1962.sp006837
Emergence of Phase- and Shift-Invariant Features by Decomposition of Natural Images into Independent Feature Subspaces, Neural Computation, vol.18, issue.7, pp.1705-1720, 2000. ,
DOI : 10.1109/TSMC.1983.6313086
A two-layer sparse coding model learns simple and complex cell receptive fields and topography from natural images, Vision Research, vol.41, issue.18, pp.2413-2423, 2001. ,
DOI : 10.1016/S0042-6989(01)00114-6
A Computational Model of the Analysis of Some First-Order and Second-Order Motion Patterns by Simple and Complex Cells, Proceedings of the Royal Society B: Biological Sciences, vol.250, issue.1329, pp.297-306, 1992. ,
DOI : 10.1098/rspb.1992.0162
An evaluation of the two-dimensional Gabor filter model of simple receptive fields in cat striate cortex, J. Neurophysiology, issue.6, pp.581233-1258, 1987. ,
Emergence of complex cell properties by learning to generalize in natural scenes, Nature, vol.9, issue.7225, pp.83-86, 2009. ,
DOI : 10.1016/j.conb.2004.07.007
Insensitivity of V1 Complex Cell Responses to Small Shifts in the Retinal Image of Complex Patterns, J. Neurophysiology, vol.78, pp.3187-3197, 1997. ,
The structure of images, Biological Cybernetics, vol.27, issue.269, pp.363-370, 1984. ,
DOI : 10.1007/BF00336961
Representation of local geometry in the visual system, Biological Cybernetics, vol.53, issue.6, pp.367-375, 1987. ,
DOI : 10.1007/BF00318371
How Are Complex Cell Properties Adapted to the Statistics of Natural Stimuli?, Journal of Neurophysiology, vol.91, issue.1, pp.206-212, 2004. ,
DOI : 10.1152/jn.00149.2003
Selectivity and sparseness in the responses of striate complex cells, Vision Research, vol.45, issue.1, pp.57-73, 2005. ,
DOI : 10.1016/j.visres.2004.07.021
Complex Receptive Fields in Primary Visual Cortex, The Neuroscientist, vol.9, issue.5, pp.317-331, 2003. ,
DOI : 10.1177/1073858403252732
Spatial frequency selectivity of cells in macaque visual cortex, Vision Research, vol.22, issue.5, pp.545-559, 1982. ,
DOI : 10.1016/0042-6989(82)90113-4
Detection and Discrimination of Relative Spatial Phase by V1 Neurons, J. Neuroscience, issue.14, pp.226129-6157, 2002. ,
On the classification of simple and complex cells, Vision Research, vol.42, issue.8, pp.1017-1013, 2002. ,
DOI : 10.1016/S0042-6989(02)00025-1
Translation-Invariant Orientation Tuning in Visual Complex Cells Could Derive from Intradendritic Computations, J. Neuroscience, issue.11, pp.184325-4334, 1998. ,
Receptive field organization of complex cells in the cat's striate cortex., The Journal of Physiology, vol.283, issue.1, pp.79-99, 1978. ,
DOI : 10.1113/jphysiol.1978.sp012489
Spatial summation in the receptive fields of simple cells in the cat's striate cortex., The Journal of Physiology, vol.283, issue.1, pp.53-77, 1978. ,
DOI : 10.1113/jphysiol.1978.sp012488
Higher Order Visual Processing in Macaque Extrastriate Cortex, Physiological Reviews, vol.88, issue.1, pp.59-89, 2008. ,
DOI : 10.1152/physrev.00008.2007
Deformable kernels for early vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.5, pp.488-499, 1995. ,
DOI : 10.1109/34.391394
Visual cortical neurons as localized spatial frequency filters, IEEE Transactions on Systems, Man, and Cybernetics, vol.13, issue.5, pp.907-916, 1983. ,
Numerical Recipes in C, 1992. ,
Hierarchical models of object recognition in cortex, Nature Neuroscience, vol.2, issue.11, pp.1019-1025, 1999. ,
Stereo disparity computation using Gabor filters, Biological Cybernetics, vol.36, issue.6, pp.405-418, 1988. ,
DOI : 10.1007/BF00336114
Internal Spatial Organization of Receptive Fields of Complex Cells in the Early Visual Cortex, Journal of Neurophysiology, vol.98, issue.3, pp.1194-1212, 2007. ,
DOI : 10.1152/jn.00429.2007
A feedforward architecture accounts for rapid categorization, Proc. Nat. Acad. Sci. USA, pp.6424-6429, 2007. ,
DOI : 10.1073/pnas.0700622104
A model of neuronal responses in visual area MT, Vision Research, vol.38, issue.5, pp.743-761, 1998. ,
DOI : 10.1016/S0042-6989(97)00183-1
Classifying simple and complex cells on the basis of response modulation, Vision Research, vol.31, issue.7-8, pp.311079-1086, 1991. ,
DOI : 10.1016/0042-6989(91)90033-2
Complex-cell receptive field models, Progress in Neurobiology, vol.31, issue.4, pp.285-309, 1988. ,
DOI : 10.1016/0301-0082(88)90016-0
An egalitarian network model for the emergence of simple and complex cells in visual cortex, Proc. Nat. Acad. Sci. USA, pp.366-371, 2004. ,
DOI : 10.1073/pnas.2036460100
Spatial Structure of Complex Cell Receptive Fields Measured with Natural Images, Neuron, vol.45, issue.5, pp.781-791, 2005. ,
DOI : 10.1016/j.neuron.2005.01.029
Slow Feature Analysis: Unsupervised Learning of Invariances, Neural Computation, vol.13, issue.11, pp.715-770, 2002. ,
DOI : 10.1016/S0301-0082(96)00054-8
Image Representation by Complex Cell Responses, Neural Computation, vol.58, issue.6, pp.2563-2575, 2004. ,
DOI : 10.1016/S0262-8856(99)00061-X
The Gaussian Derivative model for spatial-temporal vision: II. Cortical data, Spatial Vision, vol.14, issue.3, pp.321-389, 2001. ,
DOI : 10.1163/156856801753253591
The Gaussian Derivative model for spatial-temporal vision: I. Cortical model, Spatial Vision, vol.14, issue.3, pp.261-319, 2001. ,
DOI : 10.1163/156856801753253582
Winner-Take-All Networks The Handbook of Brain Theory and Neural Networks, 2003. ,
