B. D. , D. J. Burley-b, and L. D. , Octree textures Ptex: Per-face texture mapping for production rendering, Eurographics Symp. on Rendering, pp.785-790, 2002.
. [. Zimmer-h and . Kobbelt-l, Mixedinteger quadrangulation, ACM Trans. on Graphics, vol.28, issue.3, pp.1-10, 2009.
H. [. Crane-k and H. J. , Rectangular multi-chart geometry images, SGP '06: EG/ACM symp. on Geometry processing Eurographics Association, pp.181-190, 2006.
. [. Leiserson-c, . L. Rivest-r, and . Stein-c, Introduction to Algorithms, 2001.
. Eck-m, . Derose-t, . Duchamp-t, . Hoppe-h, . Lounsbery-m et al., Multiresolution analysis of arbitrary meshes, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques , SIGGRAPH '95, pp.173-182, 1995.
DOI : 10.1145/218380.218440
F. and F. M. Hormann-k, Surface parameterization: a tutorial and survey Advances in multiresolution for geometric modelling, pp.157-186, 2005.
G. F. Patow-g, Continuity mapping for multi-chart textures, SIGGRAPH Asia '09, pp.1-8, 2009.
. [. Nieser-m and . Polthier-k, Quadcover -surface parameterization using branched coverings, Computer Graphics Forum, vol.26, issue.2, pp.375-384, 2007.
L. S. Hoppe-h, Appearance-space texture synthesis, pp.541-548, 2006.
R. [. Petitjean-s and M. J. , Least squares conformal maps for automatic texture atlas generation, SIGGRAPH '02, pp.362-371, 2002.
C. [. Kumar-s, Seamless texture atlases, SGP '04: EG/ACM symp. on Geometry processing, pp.65-74, 2004.
R. N. , L. W. Lévy-b, and A. P. Sheffer-a, Periodic global parameterization, ACM Trans. Graph, vol.25, issue.4 2, pp.1460-1485, 2006.
[. N. Vallet-b, A. L. , and L. B. , Geometry-aware direction field processing, ACM Trans. Graph, vol.29, issue.1 2, pp.1-11, 2009.
H. A. Sheffer, Seamster: inconspicuous lowdistortion texture seam layout, VIS '02, pp.291-298, 2002.
[. , A. P. Cohen-steiner-d, and . M. Des-brun, Designing quadrangulations with discrete harmonic forms, SGP '06 Eurographics Association, pp.201-210, 2006.
C. [. Hormann-k, Polycube-maps, SIGGRAPH '04: ACM SIGGRAPH, pp.853-860, 2004.
. [. Keyser-j and . H. House-d, Mesh colors, ACM Trans. Graph, vol.29, issue.2, pp.1-11, 2010.
