Isotropic Remeshing with Fast and Exact Computation of Restricted Voronoi Diagram - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2009
Bruno Lévy
Yang Liu
  • Fonction : Auteur
  • PersonId : 885222
Feng Sun
  • Fonction : Auteur
  • PersonId : 885223
Wenping Wang
  • Fonction : Auteur
  • PersonId : 885224
We propose a new isotropic remeshing method, based on Centroidal Voronoi Tessellation (CVT). Constructing CVT requires to repeatedly compute Restricted Voronoi Diagram (RVD), defined as the intersection between a 3D Voronoi diagram and an input mesh surface. Existing methods use some approximations of RVD. In this paper, we introduce an efficient algorithm that computes RVD exactly and robustly. As a consequence, we achieve better remeshing quality than approximation-based approaches, without sacrificing efficiency. Our method for RVD computation uses a simple procedure and a kd-tree to quickly identify and compute the intersection of each triangle face with its incident Voronoi cells. Its time complexity is O(mlogn), where n is the number of seed points and m is the number of triangles of the input mesh. Fast convergence of CVT is achieved using a quasi-Newton method, which proved much faster than Lloyd's iteration. Examples are presented to demonstrate the better quality of remeshing results with our method than with the state-of-art approaches.
remesh.pdf (10.7 Mo) Télécharger le fichier
inria-00547790 , version 1 (17-12-2010)
Dong-Ming Yan, Bruno Lévy, Yang Liu, Feng Sun, Wenping Wang. Isotropic Remeshing with Fast and Exact Computation of Restricted Voronoi Diagram. Computer Graphics Forum, 2009, 28 (5), pp.1445-1454. ⟨10.1111/j.1467-8659.2009.01521.x⟩. ⟨inria-00547790⟩
4768 Consultations
1323 Téléchargements
