Fast Estimation of Diameter and Shortest Paths (Without Matrix Multiplication), SIAM Journal on Computing, vol.28, issue.4, pp.1167-1181, 1999. ,
DOI : 10.1137/S0097539796303421
The Moore bound for irregular graphs, Graphs and Combinatorics, pp.53-57, 2002. ,
On sparse spanners of weighted graphs, Discrete & Computational Geometry, vol.6, issue.1, pp.81-100, 1993. ,
DOI : 10.1007/BF02189308
New constructions of (?, ?)-spanners and purely additive spanners, 16 th Symposium on Discrete Algorithms (SODA), pp.672-681, 2005. ,
Fault-tolerant spanners for general graphs, 41 st Annual ACM Symposium on Theory of Computing (STOC), pp.435-444, 2009. ,
Compact roundtrip routing in directed networks, 19 th Annual ACM Symposium on Principles of Distributed Computing (PODC), pp.51-59, 2000. ,
DOI : 10.1016/j.jalgor.2003.08.001
On the locality of distributed sparse spanner construction Local computation of nearly additive spanners, 27 th Annual ACM Symposium on Principles of Distributed Computing (PODC) 23 rd International Symposium on Distributed Computing (DISC), pp.273-282, 2008. ,
Network flow spanners, th Latin American Symposium on Theoretical Informatics (LATIN), pp.410-422, 2006. ,
Computing almost shortest paths, ACM Transactions on Algorithms, vol.1, issue.2, pp.283-323, 2005. ,
DOI : 10.1145/1103963.1103968
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.5986
$(1 + \epsilon,\beta)$-Spanner Constructions for General Graphs, SIAM Journal on Computing, vol.33, issue.3, pp.608-631, 2004. ,
DOI : 10.1137/S0097539701393384
Efficient algorithms for constructing (1 + ?, ?)-spanners in the distributed and streaming models, Distributed Computing, pp.375-385, 2006. ,
Extremal problems in graph theory, in Publ, House Cszechoslovak Acad. Sci, pp.29-36, 1964. ,
Compactness results in extremal graph theory, Combinatorica, vol.66, issue.3, pp.275-288, 1982. ,
DOI : 10.1007/BF02579234
A Minimum Delay Routing Algorithm Using Distributed Computation, IEEE Transactions on Communications, vol.25, issue.1, 1977. ,
DOI : 10.1109/TCOM.1977.1093711
Remote-spanners: What to know beyond neighbors, 2009 IEEE International Symposium on Parallel & Distributed Processing, 2009. ,
DOI : 10.1109/IPDPS.2009.5161041
URL : https://hal.archives-ouvertes.fr/inria-00329347
Approximation algorithms for disjoint paths problems, 1996. ,
Staying connected in a connected world, 4th Symposium on Networked Systems Design and Implementation (NSDI), 2007. ,
Split multipath routing with maximally disjoint paths in ad hoc networks, ICC 2001. IEEE International Conference on Communications. Conference Record (Cat. No.01CH37240), pp.3201-3205, 2001. ,
DOI : 10.1109/ICC.2001.937262
Efficient algorithms for constructing fault-tolerant geometric spanners, Proceedings of the thirtieth annual ACM symposium on Theory of computing , STOC '98, pp.186-195, 1998. ,
DOI : 10.1145/276698.276734
Multipath routing in mobile ad hoc networks: Issues and challenges, in Performance Tools and Applications to Networked Systems, Revised Tutorial Lectures, pp.209-234, 2003. ,
Performance of multipath routing for on-demand protocols in mobile ad hoc networks, Mobile Networks and Applications, vol.6, issue.4, pp.339-349, 2001. ,
DOI : 10.1023/A:1011426611520
Swallow, and A. Atlas, Fast Reroute Extensions to RSVP-TE for LSP Tunnels, RFC, vol.4090, 2005. ,
Graph spanners, Journal of Graph Theory, vol.5, issue.1, pp.99-116, 1989. ,
DOI : 10.1002/jgt.3190130114
An Optimal Synchronizer for the Hypercube, SIAM Journal on Computing, vol.18, issue.4, pp.740-747, 1989. ,
DOI : 10.1137/0218050
Low distortion spanners Distributed algorithms for ultrasparse spanners and linear size skeletons, 34 th International Colloquium on Automata , Languages and Programming (ICALP) 27 th Annual ACM Symposium on Principles of Distributed Computing (PODC), pp.78-89, 2007. ,
Roundtrip spanners and roundtrip routing in directed graphs, ACM Transactions on Algorithms, vol.4, issue.3, p.29, 2008. ,
DOI : 10.1145/1367064.1367069
A quick method for finding shortest pairs of disjoint paths, Networks, vol.3, issue.2, pp.14-325, 1984. ,
DOI : 10.1002/net.3230140209
Approximate distance oracles, 17 th Symposium on Discrete Algorithms (SODA), pp.1-24, 2005. ,
DOI : 10.1145/1044731.1044732
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.295.4480
A simple approximation to minimum-delay routing, SIGCOMM, pp.227-238, 1999. ,
