Affine-Invariant Local Descriptors and Neighborhood Statistics for Texture Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We present a framework for texture recognition based on local affine-invariant descriptors and their spatial layout. At modelling time, a generative model of local descriptors is learned from sample images using the EM algorithm. The EM framework allows the incorporation of unsegmented multitexture images into the training set. The second modelling step consists of gathering co-occurrence statistics of neighboring descriptors. At recognition time, initial probabilities computed from the generative model are refined using a relaxation step that incorporates co-occurrence statistics. Performance is evaluated on images of an indoor scene and pictures of wild animals.
0649_lazebnik.pdf (1.39 Mo) Télécharger le fichier
inria-00548231 , version 1 (20-12-2010)
Svetlana Lazebnik, Cordelia Schmid, Jean Ponce. Affine-Invariant Local Descriptors and Neighborhood Statistics for Texture Recognition. 9th IEEE International Conference on Computer Vision (ICCV '03), Oct 2003, nice, France. pp.649--655, ⟨10.1109/ICCV.2003.1238409⟩. ⟨inria-00548231⟩
385 Consultations
331 Téléchargements
