Conference papers
Real Time 3D Face tracking from Appearance
Florent Duculty 1 Michel Dhome 1 Frédéric Jurie 2
2 image
LASMEA - Laboratoire des sciences et matériaux pour l'électronique et d'automatique
Abstract : We propose a real time 3D tracking algorithm dedicated to the tracking of human faces in video sequences. A face is represented by a collection of 2D images called reference views. In our approach, a pattern is a region of the image defined in an area of interest and its sampling gives a grey level vector. The tracking technique involves two stages. An off-line learning stage is devoted to the computation of an interaction matrix for every reference view. This matrix relates the grey level difference between the tracked reference pattern and the current pattern sampled inside the area of interest to its 'fronto parallel' movement (which do not modify its aspect in the image). The on-line stage consists in using this matrix to track the reference pattern in the current image. During this stage, appearance changes due to movements in roll are managed by switching between the different reference patterns. The reference pattern, after motion correction, giving the smallest grey level difference is supposed to be the new tracked reference pattern. We present experimental results showing the efficiency and the robustness of our approach.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548257
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:42:25 AM
Last modification on : Tuesday, October 5, 2021 - 4:48:03 PM
Identifiers
Collections
Citation
Florent Duculty, Michel Dhome, Frédéric Jurie. Real Time 3D Face tracking from Appearance. International Conference on Image Processing (ICIP '02), Sep 2002, New-York, United States. pp.581--584, ⟨10.1109/ICIP.2002.1038090⟩. ⟨inria-00548257⟩
Share
Metrics
Record views
25
