Conference papers
A simple and efficient template matching algorithm
Frédéric Jurie 1 Michel Dhome 2
1 image
LASMEA - Laboratoire des sciences et matériaux pour l'électronique et d'automatique
Abstract : We propose a general framework for object tracking in video images. It consists of low-order parametric models for the image motion of a target region. These models are used to predict the movement and to track the target. The difference of intensity between the pixels belonging to the current region and the pixels of the selected target (learnt during an off-line stage) allows a straightforward prediction of the region position in the current image. The proposed algorithm allows to track in real time (less than 10 ms) any planar textured target under homographic motions. This algorithm is very simple (a few lines of code) and very efficient (less than 10 ms on a 150 MHz hardware).
Document type :
Conference papers
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/inria-00548281
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Tuesday, December 21, 2010 - 2:44:41 PM
Last modification on : Tuesday, October 5, 2021 - 4:48:03 PM
Long-term archiving on: : Tuesday, March 22, 2011 - 2:34:46 AM
File
01_jurie_iccv01-1.pdf
Identifiers
Collections
Citation
Frédéric Jurie, Michel Dhome. A simple and efficient template matching algorithm. International Conference on Computer Vision (ICCV '01), Jul 2001, Vancouver, Canada. pp.544--549, ⟨10.1109/ICCV.2001.937673⟩. ⟨inria-00548281⟩
Share
Metrics
Record views
131
Files downloads
1597
