A probabilistic framework of selecting effective key frames for video browsing and indexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
To represent effectively the video content, for browsing, indexing and video skimming, the most characteristic frames (called key-frames) should be extracted from given shots. This paper, briefly reviews and evaluates the existing approaches of key-frames extraction; and then introduces a framework of selecting effective key-frames using an unsupervised clustering method. The mixture of Gaussians is used to model the temporal variation of the feature vectors of all frames in the shot. As a result, the feature-based representation of the shot is partitioned into several clusters. From each obtained cluster, firstly the closest frame to the median of its frames is selected as a reference key-frame. Then depending on the variation in time and appearance of the cluster content against the reference key-frame multiple frames can be extracted to represent effectively the cluster. The number of clusters is determined automatically by the Bayes Information Criterion. Experimental results on tracked objects in a real-world video stream are presented which illustrate the performance of the proposed technique.
Mots clés
hammoud_RISA2000.pdf (734.07 Ko) Télécharger le fichier
inria-00548295 , version 1 (21-12-2010)
  • HAL Id : inria-00548295 , version 1
Riad Hammoud, Roger Mohr. A probabilistic framework of selecting effective key frames for video browsing and indexing. International workshop on Real-Time Image Sequence Analysis (RISA '00), Aug 2000, Oulu, Finland. pp.79--88. ⟨inria-00548295⟩
146 Consultations
63 Téléchargements
