The Curvature Primal Sketch, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.1, pp.2-14, 1986. ,
DOI : 10.1109/TPAMI.1986.4767747
Parametric feature detection, International Journal of Computer Vision, vol.27, issue.1, pp.27-50, 1998. ,
DOI : 10.1023/A:1007901712605
Global measures of coherence for edge detector evaluation, Proceedings. 1999 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No PR00149), pp.373-379, 1999. ,
DOI : 10.1109/CVPR.1999.784663
Rotationally invariant image operators, Proceedings of the 4th International Joint Conference on Pattern Recognition, pp.579-583, 1978. ,
Edge detector evaluation using empirical ROC curves, Proceedings of the Conference on Computer Vision and Pattern Recognition, pp.354-359, 1999. ,
DOI : 10.1006/cviu.2001.0931
Accuracy in image measure, Proceedings of the spie Conference on Videometrics III, pp.218-228, 1994. ,
URL : https://hal.archives-ouvertes.fr/inria-00548411
A computational approach to edge detection, ieee Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.6, pp.679-698, 1986. ,
An experimental evaluation of projective invariants, Proceeding of the darpa{esprit workshop on Applications of Invariants in Computer Vision, pp.273-293, 1991. ,
Early jump-out corner detectors, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.15, issue.8, pp.823-833, 1993. ,
DOI : 10.1109/34.236246
Extraction et appariements robustes des points d'int er^ et de deux images non etalonn ees, 1994. ,
A discrete expression of Canny's criteria for step edge detector performances evaluation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.11, pp.1199-1211, 1997. ,
DOI : 10.1109/34.632980
Using Canny's criteria to derive a recursively implemented optimal edge detector, International Journal of Computer Vision, vol.1, issue.2, pp.167-187, 1987. ,
DOI : 10.1007/BF00123164
Recursively implementing the Gaussian and its derivatives, 1993. ,
Recovering and characterizing image features using an eecient model based approach, Proceedings of the Conference on Computer Vision and Pattern Recognition, pp.530-535, 1993. ,
A computational approach for corner and vertex detection, International Journal of Computer Vision, vol.8, issue.2, pp.101-124, 1993. ,
DOI : 10.1007/BF01420733
Volumetric model and 3D trajectory of a moving car derived from monocular TV frame sequences of a street scene, Computer Graphics and Image Processing, vol.20, issue.3, 1982. ,
DOI : 10.1016/0146-664X(82)90081-8
A framework for low level feature extraction, Proceedings of the 3rd European Conference on Computer Vision, pp.383-394, 1994. ,
A fast operator for detection and precise location of distinct points, corners and centres of circular features, Intercommission Conference on Fast Processing of Photogrammetric Data, pp.281-305, 1987. ,
A Combined Corner and Edge Detector, Procedings of the Alvey Vision Conference 1988, pp.147-151, 1988. ,
DOI : 10.5244/C.2.23
A robust visual method for assessing the relative performance of edge-detection algorithms, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.12, pp.1338-1359, 1997. ,
DOI : 10.1109/34.643893
Simulation of neural contour mechanisms: from simple to end-stopped cells, Vision Research, vol.32, issue.5, pp.963-981, 1992. ,
DOI : 10.1016/0042-6989(92)90039-L
Evaluation of corner extraction schemes using invariance methods, Proceedings of 13th International Conference on Pattern Recognition, pp.895-899, 1996. ,
DOI : 10.1109/ICPR.1996.546153
Finding geometric and relational structures in an image, Proceedings of the 1st European Conference on Computer Vision, pp.374-384, 1990. ,
DOI : 10.1007/BFb0014886
URL : https://hal.archives-ouvertes.fr/inria-00589995
Gray-level corner detection, Pattern Recognition Letters, vol.1, issue.2, pp.95-102, 1982. ,
DOI : 10.1016/0167-8655(82)90020-4
Representation of local geometry in the visual system, Biological Cybernetics, vol.53, issue.6, pp.367-375, 1987. ,
DOI : 10.1007/BF00318371
Morphological corner detection, Proceedings of the 6th International Conference on Computer Vision, pp.280-285, 1998. ,
Evaluation of methods for ridge and valley detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.4, pp.327-335, 1999. ,
DOI : 10.1109/34.761263
Corner detection and curve representation using cubic Bsplines . Computer Vision, Graphics and Image Processing, pp.267-278, 1987. ,
Scale-Based Description and Recognition of Planar Curves and Two-Dimensional Shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, issue.1, pp.34-43, 1986. ,
DOI : 10.1109/TPAMI.1986.4767750
Robust image corner detection through curvature scale space, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.12, pp.1376-1381, 1998. ,
DOI : 10.1109/34.735812
Towards automatic visual obstacle avoidance, Proceedings of the 5th International Joint Conference on Artiicial Intelligence, p.584, 1977. ,
Displacement vectors derived from second-order intensity variations in image sequences, Computer Vision, Graphics, and Image Processing, vol.21, issue.1, pp.85-117, 1983. ,
DOI : 10.1016/S0734-189X(83)80030-9
Junctions: detection, classification, and reconstruction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.7, pp.687-698, 1998. ,
DOI : 10.1109/34.689300
Deformable kernels for early vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.5, pp.488-499, 1995. ,
DOI : 10.1109/34.391394
URL : http://authors.library.caltech.edu/30208/1/PERcvpr91.pdf
Empirical Evaluation of Computer Vision Algorithms, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.4, pp.289-290, 1999. ,
DOI : 10.1109/TPAMI.1999.761260
Using simple decomposition for smoothing and feature point detection of noisy digital curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.8, pp.808-813, 1994. ,
DOI : 10.1109/34.308476
Context-free attentional operators: The generalized symmetry transform, International Journal of Computer Vision, vol.1, issue.11, pp.119-130, 1995. ,
DOI : 10.1007/BF01418978
Recognizing corners by fitting parametric models, International Journal of Computer Vision, vol.10, issue.2, pp.213-230, 1992. ,
DOI : 10.1007/BF00133702
Localization properties of direct corner detectors, Journal of Mathematical Imaging and Vision, vol.11, issue.2, pp.139-150, 1994. ,
DOI : 10.1007/BF01249893
Higher order differential structure of images, Image and Vision Computing, vol.12, issue.6, pp.317-325, 1994. ,
DOI : 10.1016/0262-8856(94)90056-6
Algebraic Projective Geometry, 1952. ,
Good features to track, Proceedings of the Conference on Computer Vision and Pattern Recognition, pp.593-600, 1994. ,
Ridge's corner detection and correspondence, Proceedings of IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.976-981, 1997. ,
DOI : 10.1109/CVPR.1997.609446
Comparison of edge detectors using an object recognition task, Proceedings. 1999 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No PR00149), pp.360-365, 1999. ,
DOI : 10.1109/CVPR.1999.786964
An objective comparison methodology of edge detection algorithms using a structure from motion task, Proceedings. 1998 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No.98CB36231), pp.190-195, 1998. ,
DOI : 10.1109/CVPR.1998.698608
SUSAN -a new approach to low level image processing, International Journal of Computer Vision, vol.23, issue.1, pp.45-78, 1997. ,
DOI : 10.1023/A:1007963824710
Detection and tracking of point features, 1991. ,
A robust technique for matching two uncalibrated images through the recovery of the unknown epipolar geometry, Artificial Intelligence, vol.78, issue.1-2, pp.87-119, 1995. ,
DOI : 10.1016/0004-3702(95)00022-4
URL : https://hal.archives-ouvertes.fr/inria-00074398
