Geometry of Multiple Affine Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
We introduce a unified framework for developing matching constraints of multiple affine views and rederive 2-view (affine epipolar geometry) and 3-view (affine image transfer) constraints within this framwork. With the insight into the particular structure of these multiple-view constraints, we first describe a new linear method for Euclidean motion and structure from 3 calibrated affine images. Compared with the existing linear method of Huang and Lee [6], the new method uses different and more appropriate constraints. It has no failure mode of the Euclidean factorisation method of Tomasi and Kanade [20]. We then describe how to integrate points and lines and establish some minimal point/line configurations for structure recovery. The method is demonstrated on real image sequences.
inria-00548329 , version 1 (20-12-2010)
Long Quan, Yuichi Ohta, Roger Mohr. Geometry of Multiple Affine Views. Workshop on 3D Structure from Multiple Images of Large-scale Environments (SMILE), Jan 1998, Freiburg, Germany. pp.32--46, ⟨10.1007/3-540-49437-5_3⟩. ⟨inria-00548329⟩
83 Consultations
0 Téléchargements
