New interface
Conference papers
Robust Location based Partial Correlation
Zhong-Dan Lan 1 Roger Mohr 1
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : The visual correspondence problem is a major issue in computer vision. Correlation is a common tool for this problem. Most classical correlation methods fail near the disparity discontinuities, which occur at the boundaries of objects. In this paper, a partial correlation technique is proposed to solve this problem. Robust location methods are used to perform this partial correlation. Comparisons are made with other techniques and experimental results validate the approach.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548352
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:43:39 AM
Last modification on : Friday, February 4, 2022 - 3:23:29 AM
Links full text
Identifiers
Collections
Citation
Zhong-Dan Lan, Roger Mohr. Robust Location based Partial Correlation. 7th International Conference on Computer Analysis of Images and Patterns (CAIP '97), Sep 1997, Kiel, Germany. pp.313--320, ⟨10.1007/3-540-63460-6_132⟩. ⟨inria-00548352⟩
Share
Metrics
Record views
26
