Modeling and rendering architecture from photographs: A hybrid geometry-and image-based approach, siggraph'96, 1996. ,
Occlusions and binocular stereo, Proceedings of the 2nd European Conference on Computer Vision, pp.425-433, 1992. ,
In defence of the 8-point algorithm, Proceedings of the 5th International Conference on Computer Vision, pp.1064-1070, 1995. ,
Virtualized reality: Concepts and early results, Workshop on Representation of Visual Scenes, pp.69-76, 1995. ,
3D surface reconstruction from stereoscopic image sequences, Proceedings of the 5th International Conference on Computer Vision, pp.109-114, 1995. ,
Appariement robuste par correlation partielle, Journ ees ORASIS 1996, pp.99-104, 1996. ,
Direct linear sub-pixel correlation by incorporating neighbour pixels' information: a robust and precise matching method, 1996. ,
Precise matching by robust estimation of deformation and local coherence, 1996. ,
3D scene representation as a collection of images and fundamental matrices, 1994. ,
Pel e. An approach for scene reconstruction from the analysis of a triplet of still images, Electronic Imaging, 1997. ,
Light eld rendering, siggraph 1996, pp.31-42, 1996. ,
Matrice fondamentale et autocalibration en vision par ordinateur, 1992. ,
Trinocular image analysis for virtual frame reconstruction, 1996. ,
Stereo by intra and inter-scanline search using dynamic programming, ieee Transactions on Pattern Analysis and Machine Intelligence, vol.7, issue.2, pp.139-154, 1985. ,
Application de la g eom etrie projective a la compression en TV3D, Journ ees ORASIS 1996, pp.129-134, 1996. ,
Image retrieval using local characterization, Proceedings of the ieee International Conference on Image Processing, pp.781-784, 1996. ,
Trilinearity in visual recognition by alignment, Proceedings of the 3rd European Conference on Computer Vision, pp.479-484, 1994. ,
Rendering real-world objects without 3D model nn am, p.12135, 1994. ,
A robust technique for matching two uncalibrated images through the recovery of the unknown epipolar geometry, 1994. ,
