New interface
Other publications
The Geometry of Projective Reconstruction I: Matching Constraints and the Joint Image
Bill Triggs 1
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : This paper studies the geometry of perspective projection into multiple images and the matching constraints that this induces between the images. The combined projections produce a 3D subspace of the space of combined image coordinates called the joint image. This is a complete projective replica of the 3D world defined entirely in terms of image coordinates, up to an arbitrary choice of certain scale factors. Projective reconstruction is a canonical process in the joint image requiring only the rescaling of image coordinates. The matching constraints tell whether a set of image points is the projection of a single world point. In 3D there are only three types of matching constraint: the fundamental matrix, Shashua's trilinear tensor, and a new quadrilinear 4 image tensor. All of these fit into a single geometric object, the joint image Grassmannian tensor. This encodes exactly the information needed for reconstruction: the location of the joint image in the space of combined image coordinates.
Document type :
Other publications
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/inria-00548382
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:44:10 AM
Last modification on : Friday, February 4, 2022 - 3:32:25 AM
Long-term archiving on: : Monday, March 21, 2011 - 3:00:18 AM
Triggs-ijcv95.pdf
Identifiers
  • HAL Id : inria-00548382, version 1
Collections
Citation
Bill Triggs. The Geometry of Projective Reconstruction I: Matching Constraints and the Joint Image. 1995. ⟨inria-00548382⟩
Share
Metrics
Record views
176
Files downloads
907
