New interface
Conference papers
The Advantage of Mounting a Camera onto a Robot Arm
Radu Horaud 1, 2 Roger Mohr 1, 2 Fadi Dornaika 2 Boubakeur Boufama 1, 2
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : In this paper we describe a method for recovering Euclidean structure of an unknown scene with an uncalibrated camera mounted onto a robot arm. More precisely the method achieves the following tasks : the projective structure of the scene obtained with a projective reconstruction algorithm is converted into an Euclidean structure and the intrinsic camera parameters are estimated as well as the hand/eye calibration parameters. We cast the problem into a simple set of matrix equations and we determine under which motions the solution is unique. Then we provide a simple algorithm for implementing the method in practice. Finally the experimental results obtained with our method are compared with classical camera and hand/eye calibration techniques.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548389
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, January 3, 2011 - 2:44:46 PM
Last modification on : Wednesday, May 4, 2022 - 12:12:03 PM
Long-term archiving on: : Monday, April 4, 2011 - 2:34:51 AM
File
the-advantage-of-mounting.pdf
Identifiers
  • HAL Id : inria-00548389, version 1
Collections
Citation
Radu Horaud, Roger Mohr, Fadi Dornaika, Boubakeur Boufama. The Advantage of Mounting a Camera onto a Robot Arm. Europe-China Workshop on Geometrical Modelling and Invariants for Computer Vision, Xian, China, Apr 1995, Xian, China. pp.206--213. ⟨inria-00548389⟩
Share
Metrics
Record views
205
Files downloads
72
