Independent Motion Segmentation and Collision Prediction for Road vehicules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
This paper presents a method for doing motion segmentation for autonomous vehicles which drive on planar surfaces. There are two distinct types of independent motion that may occur within an image sequence taken from a moving vehicle. The first generic type of independent motion is when the projected motion of points on the independent object violate the epipolar constraint. The second case is where the epipolar constraint is not violated. This paper demonstrates that it is possible to detect this second type of independent motion by looking for progressive dis-occlusion of the road. A novel collision prediction method is also given. The method predicts the projection of a corridor down which the AGV will travel. This prediction may be used for time to contact collision prediction and the corridor width embodies an estimate of the vehicles size
Fichier non déposé
inria-00548406 , version 1 (20-12-2010)
David Sinclair, Boubakeur Boufama, Roger Mohr. Independent Motion Segmentation and Collision Prediction for Road vehicules. International Conference on Computer Vision & Pattern Recognition (CVPR '94), Jun 1994, Seattle, United States. pp.958--961, ⟨10.1109/CVPR.1994.323933⟩. ⟨inria-00548406⟩
53 Consultations
0 Téléchargements
