New interface
Conference papers
An Egomotion Algorithm Based on the Tracking of Arbitrary Curves
Emmanuel Arbogast 1 Roger Mohr 1, 2
2 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : We are interested in the analysis of non polyhedral scenes. We will present an original egomotion algorithm, based on the tracking of arbitrary curves in a sequence of gray scale images. This differential method analyses the spatiotemporal surface, and extracts a simple equation relating the motion parameters and measures on the spatiotemporal surface. When a curve contour line is tracked in image sequence, this equation allows to extract the 3D motion parameters of the object attached to the contour when rigid motion is assumed. Experiments on synthetic as well as real data show the validity of this method.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548441
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:44:53 AM
Last modification on : Friday, February 4, 2022 - 3:23:29 AM
Links full text
Identifiers
Collections
Citation
Emmanuel Arbogast, Roger Mohr. An Egomotion Algorithm Based on the Tracking of Arbitrary Curves. European Conference on Computer Vision (ECCV '92), May 1992, Santa Margherita Ligure, Italy. pp.467--475, ⟨10.1007/3-540-55426-2_52⟩. ⟨inria-00548441⟩
Share
Metrics
Record views
36
