3D Structure Inference from Image Sequences
Abstract : We prove here that the observation of occluding contours together with a movement of the camera permits the reconstruction of an observed surface. This result is demonstrated under very light constraints, generalizing previous results. Thus, the technique presented can be applied with any movement of the camera, under perspective projection, with surface C1 by parts or even with lines of discontinuity. It allows recovery of the structure of three-dimensional shapes with complex surfaces.
Type de document :
Communication dans un congrès
H.S. Baird. Syntactical and Structural Pattern Recognition, 1990, New York, United States. pp.21--37, 1990
Liste complète des métadonnées
https://hal.inria.fr/inria-00548464
Contributeur : Thoth Team <>
Soumis le : lundi 20 décembre 2010 - 08:46:53
Dernière modification le : jeudi 11 janvier 2018 - 06:23:18
  • HAL Id : inria-00548464, version 1
Collections
Citation
Emmanuel Arbogast, Roger Mohr. 3D Structure Inference from Image Sequences. H.S. Baird. Syntactical and Structural Pattern Recognition, 1990, New York, United States. pp.21--37, 1990. 〈inria-00548464〉
Métriques
Consultations de la notice
142
