New interface
Reports (Research report)
Matching 3D Images without Backtracking Through Feature Grouping
Abstract : This paper deals with the problem of building a 3-D model of the environnment for a mobile robot by combining several 3-D images obtained from stereo vision. A new method for 3-D image matching is described. It is based on a coarse to fine approach allowing a good initial estimation of the robot motion. We show the importance of feature grouping and how feature groups can be used to guide the search. The experimental results demonstrate a significant reduction in the complexity of the matching problem and low sensitivity to noise.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00548472
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:47:52 AM
Last modification on : Wednesday, October 26, 2022 - 8:16:37 AM
Identifiers
  • HAL Id : inria-00548472, version 1
Collections
Citation
Éric Thirion, Roger Mohr. Matching 3D Images without Backtracking Through Feature Grouping. [Research Report] 88-R-020, 1988. ⟨inria-00548472⟩
Share
Metrics
Record views
22
