Conference papers
Recognizing and Locating Polyhedral Objects from Sparse Range Data
Abstract : A model-based approach is described for recognizing and locating polyhedral objects from sparse light-stripe data. Based on two scans, consistent interpretations are provided by locating scanned line segments on the faces of a set of known objects. The transformation associated with each interpretation is estimated. Once all the feasible models are transformed to the scene space, a strategy for additional scanning positions is developed to distinguish the object uniquely.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00548477
Contributor : THOTH Team Connect in order to contact the contributor
Submitted on : Monday, December 20, 2010 - 8:48:37 AM
Last modification on : Friday, February 26, 2021 - 3:26:01 PM
Identifiers
Collections
Citation
Shijia Qiang, Roger Mohr, Karl Tombre. Recognizing and Locating Polyhedral Objects from Sparse Range Data. 9th International Conference on Pattern Recognition (ICPR '88), Nov 1988, Rome, Italy. pp.104--106, ⟨10.1109/ICPR.1988.28182⟩. ⟨inria-00548477⟩
Share
Metrics
Record views
192
